Brand new to ODK and trying to get started. searched for solution but no success.
Trying to upload ODK Aggregate.
I have done the step of Java 7 exception list (adding, "file:///")
Below is my output.
Appreciate any suggestions.
thanks -
listBackends : Reading application configuration data...
listBackends!: Dec 15, 2016 7:21:37 PM com.google.apphosting.utils.config.IndexesXmlReader readConfigXml
listBackends!: INFO: Successfully processed ./LegacyRemoval\WEB-INF/datastore-indexes.xml
listBackends :
listBackends :
listBackends : Beginning interaction for module default...
listBackends : Warning: This application uses Backends, a deprecated feature that has been replaced by Modules, which offers additional functionality. Please convert your backends to modules as described at: https://developers.google.com/appengine/docs/java/modules/converting.
listBackends!: Dec 15, 2016 7:21:37 PM com.google.appengine.tools.admin.AbstractServerConnection send1
listBackends!: WARNING: Error posting to URL: https://appengine.google.com/api/backends/list?app_id=kgtestcare&
listBackends!: 404 Not Found
listBackends!: This application does not exist (project_id=u'kgtestcare'). To create an App Engine application in this project, run "gcloud beta app create" in your console.
listBackends!: This is try #0
listBackends!: Dec 15, 2016 7:21:38 PM com.google.appengine.tools.admin.AbstractServerConnection send1
listBackends!: This is try #1
listBackends!: This is try #2
listBackends!: This is try #3
listBackends : Unable to list backends: Error posting to URL: https://appengine.google.com/api/backends/list?app_id=kgtestcare&
listBackends : 404 Not Found
listBackends : This application does not exist (project_id=u'kgtestcare'). To create an App Engine application in this project, run "gcloud beta app create" in your console.
listBackends :
listBackends : Please see the logs [C:\Users\KATENT~1\AppData\Local\Temp\appcfg8128025701419338251.log] for further information.
listBackends :
listBackends!:
status : Action failed or aborted by user
I am having the same issue and cannot find any clue.
On Thursday, December 15, 2016 at 2:03:22 PM UTC-5, ritte...@gmail.com wrote:
> success.
> Below is my output.
> thanks -
> listBackends :
> listBackends :
> listBackends :
> listBackends :
> listBackends!:
Im not sure, isnt it just https://project_id.appspot.com
with my project id inserted?
On Friday, December 16, 2016 at 4:56:45 PM UTC+7, Manish Dhruw wrote:
> it says This application does not exist (project_id=u'kgtestcare')
> can you tell What is your appspot url
I had the same issue, and after contacting the google support I realized
that now it's not enough to create an empty project, you have to creat an
appengine project too. So try to create an appengine project from the
existing one at google cloud's consol page. You can do that after selecting
your project, click at the upper left corner and search for the appengine
page. There you have to click on the "first app " window, select the java
option and follow the further instructions (you can cancel the tutorial, it
was enough for me to create the app engine project itself).
After these I managed to upload the aggregate by following the instructions
from the ODK's webpage.
december 18., vasárnap 2:41:56 UTC+1 időpontban A.N.M AL-IMRAN a
>> success.
>> Below is my output.
>> thanks -
>> listBackends :
>> listBackends :
>> listBackends :
>> listBackends :
>> listBackends!:
Thanks a lot for sharing you recovery experience. That helped me a lot, I
have managed to complete installation process following your instruction.
On Monday, December 19, 2016 at 3:35:40 AM UTC-5, M_Cs wrote:
> Hi!
> instructions from the ODK's webpage.
> 2016. december 18., vasárnap 2:41:56 UTC+1 időpontban A.N.M AL-IMRAN a
>>> success.
>>> Below is my output.
>>> thanks -
>>> listBackends :
>>> listBackends :
>>> listBackends :
>>> listBackends :
>>> listBackends!:
