A 404 Not Found error saying ODKAggregate/Aggregate.html is not found
I have installed ODK aggregate on a server with Tomcat and MySQL .USING the
sofeware for port map, I have two url for ODK aggregate, one is in the
readme file generated by installing ODK Aggregate v1.4.5
windows-installer.exe. it is http://odk1234.nat123.net:8080/ODKAggregate/
called internal url. one is http://odk1234.nat123.net:11835/ODKAggregate /
called external url . the external url work well for everyone on internet.
when I hit the internal url ,it gives a 404 Not Found error saying
ODKAggregate/Aggregate.html is not found.
The ODK Aggregate configuration process only supports one URL for a given
ODK Aggregate -- the software will forcibly drive all traffic to use that
one URL by issuing redirects or possibly silently ignoring traffic on the
other URL, even if there are other valid URLs / paths to the server.
When configuring ODK Aggregate, you should specify the external URL in the
installer.
This is especially important if you are using a firewall to redirect
traffic from port 11835 to port 8080 on which the Tomcat server is running
on your computer - you would specify port 11835 within the installer.
Explicitly forcing all traffic to use one URL simplifies operations when
using SSL certificates, avoids difficult-to-diagnose cross-site scripting
webpage problems, and ensures that CSV exports that contain URLs to media
are using the correct URL for everyone (it would be a nightmare if a
generated CSV had different media link URLs depending upon whether you
generated it from your office, your home, or at a WiFi hotspot).
the sofeware for port map, I have two url for ODK aggregate, one is in the
/ called external url . the external url work well for everyone on
internet. when I hit the internal url ,it gives a 404 Not Found error
saying ODKAggregate/Aggregate.html is not found.
