Is it possible to accelerate the GPS positioning widget. Each time it's
like all the process begins from the very start point. I imagine more like
a constantly running GPS widget that can send a accurate position on demand
since it's already lock on satellites.
My issue comes from a lots of different points to collect in a short time
when I also need a acceptable accuracy position.
Thanks!
Others have integrated external GPS systems with ODK Collect to create
high-accuracy traces.
Can anyone share what they have done?
The GPS system creates a heavy drain on the battery, so it generally is
turned on, a point is sampled, and it is turned off.
On Fri, Mar 27, 2015 at 8:57 AM, Alexandre Giasson < giasson.alexandre@gmail.com> wrote:
Thanks!
