Accessing ODK Central data to Power Bi dashboard
I used to track data from odk central to power bi dashbaord but now "acces to the resouce forbidden" message is popping up and could not update and get the data. Your support is highly appreciated, and thanks
I have made some edits on the queries and the problem started there. When I wan to create a new power bi dashboard to start as a new and tried to link the URL odata the above message comes. I have a full access on odd central with administrator privilege and created the project itself.
I would check that you can still login to your Central server with your credentials. If your username and password are still working well to login on Central, try to refresh your credentials for the data source in PowerBi as it it likely a problem there. This Microsoft support forum post includes instructions for a Credential Scope Reset, which is one additional way you could try to fix it inside PowerBi.
