Hello everyone!
Do you know how can I add appareance tags like "w2" (with this one I could tell enketo grid theme to split in two columns) or "hide-input" (to disable altitude input) in geopoints at the builder app (https://build.getodk.org/)?
Advanced properties only has "show if", "constraints", "Constraint Invalid Text" and "calculate"
The only way I find to do this is to export as xlsForm, add it manually and then generate the xml from it
Thanks in advance
