You can already add arbitrary columns to XLSForms and they will be
passed through to the XML, so there is nothing preventing you from
doing this already.
If the goal is to get this new column as something that's standard in
all forms, then I think there needs to be a longer discussion around
what high level problem you are trying to solve and why you think this
solution is generic and ideal.
On Sun, Feb 15, 2015 at 1:18 PM, Matt Berg mlberg@gmail.com wrote:
We are exploring the idea of adding a "code" column to XLS Forms.
The idea is to be able to code medical concept ids or things like HXL tags
into forms.
First, I just wanted to see if the community had an issue with this
approach.
Ie) should we use a new column or should we just use a label instead. ie)
label:code
Second, should we use code or another word like concept?
Higher level problem is we want to create forms that can map to openmrs
concept ids. Another use case is tagging for things like hxl tags.
We could use the name space for these but this makes forms non human
readable. Also, there may be cases there you just want to code a subset
of values in a form and do this retrospectively.
Code to me seems like a term that would work well but am open to other
suggestions. I could also see allowing people to do things like code:hxl
code:iso9 (Two columns) if people wanted to use more then one coding
standard in form or just to provide a bit more detail what coding approach
is being used.
We would like to standardize this approach as we will build tools around
this. Ie) data export that supports hxl.
Note we will need to include codes on options tab too.
Thoughts everyone?
Matt
On Feb 15, 2015 11:27 PM, "Yaw Anokwa" wrote:
Matt,
doing this already.
tags
into forms.
approach.
ie)
label:code
It's a good idea to sort out a method of including form- and field-specific
export options. With so many different ways of exporting data from ODK
systems, the method we've been using -- configure all export options on the
exporting computer -- is probably not idea. I could see a different state
of the world where the form itself has everything needed to know how to
export it.
"code" seems to me a little generic, though, and could refer to any number
of things. What if we started using an "export:" prefix followed by
different things for different export systems? So we might have
"export:stata:x", "export:googleearth:y", and "export:hxl:z".
Ideally, we'd support export-related columns both on the survey sheet and
on the settings sheet (for field-specific and form-wide export options
respectively).
Chris
On Mon Feb 16 2015 at 12:28:31 AM Matt Berg wrote:
Yaw,
Thanks that's very helpful.
is being used.
doing this already.
tags
into forms.
approach.
ie)
label:code
Seems fine to me to add attributes to primary XML instance nodes and
leave those attributes unchanged when submitting a record. I think the
actual exporting/transforming to a particular format is something that the
client should not concern itself with. This should be up to the server
after receiving the submission.
If we foresee a need for multiple formats in the future, using a generic code: (or something else) namespace, as Matt suggested (so code:hxl=""),
would be sensible, since it seems unlikely we'd want to add several
different coding formats to the same form. We should define the namespace
and the different formats in the XForm spec, so the forms can be moved. Not
sure what namespace url we should use.
Matt, the use case does not include adding codes to values (e.g. select one
values), right? That would be a different story...
Cheers,
Martijn
On Monday, February 16, 2015 at 5:07:28 AM UTC-7, Christopher Robert wrote:
> Hi Matt,
> field-specific export options. With so many different ways of exporting
> data from ODK systems, the method we've been using -- configure all export
> options on the exporting computer -- is probably not idea. I could see a
> different state of the world where the form itself has everything needed to
> know how to export it.
> respectively).
> Best,
> Chris
> On Mon Feb 16 2015 at 12:28:31 AM Matt Berg <mlb...@gmail.com > wrote:
>> Yaw,
>> is being used.
>> Thoughts everyone?
>> Matt
>> On Feb 15, 2015 11:27 PM, "Yaw Anokwa" <yan...@nafundi.com > wrote:
>>> Matt,
>>> doing this already.
>>> https://github.com/XLSForm/pyxform/commit/ac2d3811822c533f9ac1b18315ef6cfabf816fe3
>>> Yaw
>>> tags
>>> > into forms.
>>> > approach.
>>> ie)
>>> > label:code
>>> > Thanks,
>>> > Matt
>>> > You received this message because you are subscribed to the Google
>>> Groups
>>> > "ODK Developers" group.
>>> > To unsubscribe from this group and stop receiving emails from it, send
>>> an
>>> > email to opendatakit-developers+unsubscribe@googlegroups.com
>>> > For more options, visit https://groups.google.com/d/optout.
>>> Groups "ODK Developers" group.
>>> an email to opendatakit-developers+unsubscribe@googlegroups.com
*Revolutionizing data collection since 2012.*
I am unclear where these new attributes would live....
They could be on the s or within the submission instance XML
(declared within the main ).
If they are within the then you could use XLSTs to transform
things (I think this is what Martijn is envisioning?)
If they are within the then it is up to the hosting system to
interpret these attributes and handle them as it sees fit.
Note that the namespace alias ('code' or 'export') is arbitrary. The
namespace URI is what should be compared when coding.
'export' gets my vote.
one values), right? That would be a different story...
Cheers,
Martijn
Hi Matt,
number of things. What if we started using an "export:" prefix followed by
respectively).
Chris
On Mon Feb 16 2015 at 12:28:31 AM Matt Berg mlb...@gmail.com wrote:
Yaw,
is being used.
doing this already. https://github.com/XLSForm/pyxform/commit/
tags
into forms.
approach.
instead. ie)
label:code
If we're leaving the transforming/exporting (to HXL) to the server (i.e.
Aggregate, Ona etc), then the best place would be in the primary instance
of the XForm.
If the transforming (to HXL) happens on the client (i.e. Enketo or ODK
Collect) then adding the attributes to seems to make the most sense.
This is not a feature that I would support as I don't think it belongs on
the client.
Yes, true about the namespace URI being the only one that matters.
On Tue, Feb 17, 2015 at 8:23 AM, Martijn van de Rijdt martijn@enketo.org wrote:
Cheers,
Martijn
Hi Matt,
and on the settings sheet (for field-specific and form-wide export options
respectively).
Chris
Yaw,
is being used.
around this. Ie) data export that supports hxl.
HXL tags
into forms.
approach.
instead. ie)
label:code
w.r.t. (1) -- this depends upon whether the server has access to the form
definition or not. If the server has the form definition, the presence of
the information in the submission XML is not as important. Having it in the
submission does, however, facilitate XLST manipulations.
On the other hand, having the attributes in the s keeps the byte
count of the filled-in form XML low -- that XML would not contain any of
these (boilerplate) transformation attributes that do not change from one
filled-in form to the next (or are determined by the specific version of
the form definition used when filling out the submission).
On Tue, Feb 17, 2015 at 12:07 PM, Martijn van de Rijdt wrote:
Yes, we need to clarify that.
(i.e. Aggregate, Ona etc), then the best place would be in the primary
instance of the XForm.
the client.
On Tue, Feb 17, 2015 at 8:23 AM, Martijn van de Rijdt <martijn@enketo.org wrote:
Cheers,
Martijn
Hi Matt,
respectively).
Chris
Yaw,
openmrs concept ids. Another use case is tagging for things like hxl
tags.
is being used.
HXL tags
into forms.
approach.
instead. ie)
label:code
Yes, valid points. If #1 is what we're after, my vote goes for adding them
to the XML record but I'd have no objection to adding them to the s.
In my opinion, it seem more logical to tag the fields in the record instead
of requiring the additional processing to extract them from binds on the
server side.
For #1 'tag' is another option as the column name in XLSForm (and namespace
alias in XForm although as Mitch explained, it doesn't matter). I like
'tag' (or 'code') because I think the feature could perhaps also be used to
directly store any submitted data in HXL format in some custom server (no
'export'). It's a less opinionated name and describes better what it does
from the form format's perspective.
> Mitch
> On Tue, Feb 17, 2015 at 12:07 PM, Martijn van de Rijdt <mar...@enketo.org > wrote:
>> 1. If we're leaving the transforming/exporting (to HXL) to the server
>> 2. If the transforming (to HXL) happens on the client (i.e. Enketo or ODK
>> the client.
>> On Tue, Feb 17, 2015 at 12:19 PM, Mitch Sundt <mitche...@gmail.com > wrote:
>>> - If they are within the then you could use XLSTs to
>>> transform things (I think this is what Martijn is envisioning?)
>>> - If they are within the then it is up to the hosting system to
>>> On Tue, Feb 17, 2015 at 8:23 AM, Martijn van de Rijdt <mar...@enketo.org > wrote:
>>>> Seems fine to me to add attributes to *primary XML instance nodes* and
>>>> generic `code:` (or something else) namespace, as Matt suggested (so
>>>> code:hxl=""), would be sensible, since it seems unlikely we'd want to add
>>>> several different coding formats to the same form. We should define the
>>>> namespace and the different formats in the XForm spec, so the forms can be
>>>> moved. Not sure what namespace url we should use.
>>>> Cheers,
>>>> Martijn
>>>>> Hi Matt,
>>>>> respectively).
>>>>> Best,
>>>>> Chris
>>>>>> Yaw,
>>>>>> tags.
>>>>>> other suggestions. I could also see allowing people to do things like
>>>>>> code:hxl code:iso9 (Two columns) if people wanted to use more then one
>>>>>> coding standard in form or just to provide a bit more detail what coding
>>>>>> approach is being used.
>>>>>> Thoughts everyone?
>>>>>> Matt
>>>>>>> Matt,
>>>>>>> doing this already.
>>>>>>> this
>>>>>>> Yaw
>>>>>>> HXL tags
>>>>>>> > into forms.
>>>>>>> > approach.
>>>>>>> instead. ie)
>>>>>>> > label:code
>>>>>>> > Thanks,
>>>>>>> > Matt
>>>>>>> Groups
>>>>>>> send an
>>>>>>> > email to opendatakit-developers+unsubscribe@googlegroups.com.
>>>>>>> send an email to opendatakit-developers+unsubscribe@googlegroups.com
>>>>>> send an email to opendatakit-developers+unsubscribe@googlegroups.com.
>>>> Enketo | LinkedIn
>>>> | GitHub
>>>> | Twitter
>>>> | Blog
>>> Mitch Sundt
>>> Software Engineer
>>> University of Washington
>>> mitche...@gmail.com
>>> You received this message because you are subscribed to a topic in the
>>> Google Groups "ODK Developers" group.
>>> To unsubscribe from this topic, visit
>>> https://groups.google.com/d/topic/opendatakit-developers/hESE9Diqcq0/unsubscribe
>>> To unsubscribe from this group and all its topics, send an email to
>>> opendatakit-developers+unsubscribe@googlegroups.com .
>> Enketo | LinkedIn
>> | GitHub
>> | Twitter
>> | Blog
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Bit lost on how to do this technically but agree not sure export is ideal
as this is also meant to allow us to specify how we store things internally
so I think something like code, tag or even map works better.
Keen to decide on an approach though as this is something we need to
implement for a few projects soon.
Matt
server side.
namespace alias in XForm although as Mitch explained, it doesn't matter). I
like 'tag' (or 'code') because I think the feature could perhaps also be
used to directly store any submitted data in HXL format in some custom
server (no 'export'). It's a less opinionated name and describes better
what it does from the form format's perspective.
On Tue, Feb 17, 2015 at 12:07 PM, Martijn van de Rijdt <mar...@enketo.org wrote:
ODK Collect) then adding the attributes to seems to make the most
sense. This is not a feature that I would support as I don't think it
belongs on the client.
On Tue, Feb 17, 2015 at 8:23 AM, Martijn van de Rijdt < mar...@enketo.org> wrote:
and leave those attributes unchanged when submitting a record. I think the
select one values), right? That would be a different story...
Cheers,
Martijn
Hi Matt,
respectively).
Chris
Yaw,
tags.
in
this
HXL tags
into forms.
this
approach.
instead. ie)
label:code
send an email to opendatakit-developers+unsubsc ribe@googlegroups.com.
Just simple tagging of questions with a code is what you're after, right?
No tagging of specific select_one or select_multiple values, right?
Cheers,
Martijn
> Thanks,
> Matt
> On Feb 19, 2015 7:25 PM, "Martijn van de Rijdt" <mar...@enketo.org > wrote:
>> them to the XML record but I'd have no objection to adding them to the
>> s. In my opinion, it seem more logical to tag the fields in the
>> record instead of requiring the additional processing to extract them from
>> binds on the server side.
>>> form definition or not. If the server has the form definition, the presence
>>> of the information in the submission XML is not as important. Having it in
>>> the submission does, however, facilitate XLST manipulations.
>>> Mitch
>>> On Tue, Feb 17, 2015 at 12:07 PM, Martijn van de Rijdt < mar...@enketo.org> wrote:
>>>>>> Cheers,
>>>>>> Martijn
>>>>>>> Hi Matt,
>>>>>>> sheet and on the settings sheet (for field-specific and form-wide export
>>>>>>> options respectively).
>>>>>>> Best,
>>>>>>> Chris
>>>>>>>> Yaw,
>>>>>>>> tags.
>>>>>>>> human readable. Also, there may be cases there you just want to code a
>>>>>>>> subset of values in a form and do this retrospectively.
>>>>>>>> Thoughts everyone?
>>>>>>>> Matt
>>>>>>>>> Matt,
>>>>>>>>> doing this already.
>>>>>>>>> in
>>>>>>>>> around
>>>>>>>>> this
>>>>>>>>> Yaw
>>>>>>>>> like HXL tags
>>>>>>>>> > into forms.
>>>>>>>>> this
>>>>>>>>> > approach.
>>>>>>>>> instead. ie)
>>>>>>>>> > label:code
>>>>>>>>> > Thanks,
>>>>>>>>> > Matt
>>>>>>>>> Google Groups
>>>>>>>>> it, send an
>>>>>> Enketo | LinkedIn
>>>>>> | GitHub
>>>>>> | Twitter
>>>>>> | Blog
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>>>> To unsubscribe from this topic, visit https://groups.google.com/d/
>>>>> topic/opendatakit-developers/hESE9Diqcq0/unsubscribe.
>>>> Enketo | LinkedIn
>>>> | GitHub
>>>> | Twitter
>>>> | Blog
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
>> Enketo | LinkedIn
>> | GitHub
>> | Twitter
>> | Blog
On Feb 23, 2015 8:02 PM, "Martijn van de Rijdt" wrote:
Matt,
Cheers,
Martijn
Matt
to interpret these attributes and handle them as it sees fit.
Cheers,
Martijn
Hi Matt,
Chris
Yaw,
tags.
standard in
around
this
server
Forms.
like HXL tags
into forms.
this
approach.
instead. ie)
label:code
Hmm. That changes everything. Unless somebody has an idea to add this to
the XForm format nicely, I'm wondering if a better approach would be to
keep this outside of the XForm format and data collection clients entirely.
Maybe instead only include this in the JSON XLSForm output, and process
traditional XML records when they are submitted?
On Monday, February 23, 2015 at 11:55:38 AM UTC-7, Matt Berg wrote:
> No we need the ability to code options too
> On Feb 23, 2015 8:02 PM, "Martijn van de Rijdt" <mar...@enketo.org > wrote:
>> Matt,
>> Cheers,
>> Martijn
>>> ideal as this is also meant to allow us to specify how we store things
>>> internally so I think something like code, tag or even map works better.
>>> Thanks,
>>> Matt
>>>>> Mitch
>>>>>>> The namespace URI is what should be compared when coding.
>>>>>>>> Cheers,
>>>>>>>> Martijn
>>>>>>>>> Hi Matt,
>>>>>>>>> any number of things. What if we started using an "export:" prefix followed
>>>>>>>>> by different things for different export systems? So we might have
>>>>>>>>> Best,
>>>>>>>>> Chris
>>>>>>>>>> Yaw,
>>>>>>>>>> tags.
>>>>>>>>>> Thoughts everyone?
>>>>>>>>>> Matt
>>>>>>>>>>> Matt,
>>>>>>>>>>> be
>>>>>>>>>>> from
>>>>>>>>>>> doing this already.
>>>>>>>>>>> standard in
>>>>>>>>>>> around
>>>>>>>>>>> think this
>>>>>>>>>>> Yaw
>>>>>>>>>>> server
>>>>>>>>>>> Forms.
>>>>>>>>>>> like HXL tags
>>>>>>>>>>> > into forms.
>>>>>>>>>>> this
>>>>>>>>>>> > approach.
>>>>>>>>>>> instead. ie)
>>>>>>>>>>> > label:code
>>>>>>>>>>> > Thanks,
>>>>>>>>>>> > Matt
>>>>>>>>>>> Google Groups
>>>>>>>>>>> it, send an
>>>>>>>>>>> it, send an email to opendatakit-developers+unsubsc
>>>>>>>> Enketo | LinkedIn
>>>>>>>> | GitHub
>>>>>>>> | Twitter
>>>>>>>> | Blog
>>>>>>> Mitch Sundt
>>>>>>> Software Engineer
>>>>>>> mitche...@gmail.com
>>>>>>> the Google Groups "ODK Developers" group.
>>>>>>> To unsubscribe from this topic, visit https://groups.google.com/d/to
>>>>>> Enketo | LinkedIn
>>>>>> | GitHub
>>>>>> | Twitter
>>>>>> | Blog
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>>> Enketo | LinkedIn
>>>> | GitHub
>>>> | Twitter
>>>> | Blog
>> Enketo | LinkedIn
>> | GitHub
>> | Twitter
>> | Blog
