Is it possible to have dependency to multi-choice question options?
*For Example:
*I have two questions.
Username question (alpha-numeric)
Based upon username i'm going to display multi-choice question with lot
of options, in this case options has dependency with username (i.e some
case it'll be two options or some case it'll be three options)
I don't want to duplicate multi-choice question as 2.1, 2.2 and etc.
Can you suggest / give some valuable feedback to achieve this?
If you have a limited number of user names, you can still do this with
relevance constraints. However, if the number of user names is extensive
you are going to need to insert some special-purpose code into ODK Collect.
Gaetano
On Tue, Feb 21, 2012 at 11:13 PM, res tester wrote:
Hi Team,
*For Example:
