Hiya,
I am creating a form in the xls form builder and have come across an issue with the choice filter column. Can anyone help?
Q1. A select multiple question which lists types of reading materials available.
Q2. A select multiple question asking which of these reading materials are available in a specific language
I use a choice filter to restrict the options in the second question to those that have been chosen in the first.
However,
the second question also needs an option of "none". I can't work out what the synatax should be ( if it is possible) to have the answers from Q1 PLUS "none" as options for the second question. I have tried everything I can think of!
Here is what i have that works just for the answers from question 1
type | name | label | choice_filter |
select_multiple management_materials | management_materials | Please show me the guidelines for lymphedema management present at this facility | |
select_multiple management_materials_local | management_materials_local | Which of these lymphoedema management guidelines are available in the local language? | selected($({management_materials} |
I
