Aggregate Cli dont connect a external postgresql
I have the next config json:
"home": "/root",
"jdbc": {
"host": "192.168.0.34",
"port": 5432,
"db": "aggregate",
"schema": "aggregate",
"user": "aggregate",
"password": "aggregate1"
"security": {
"hostname": "192.168.0.46:8080",
"forceHttpsLinks": false,
"port": 8080,
"securePort":445,
"checkHostnames": false
"tomcat": {
"uid": "tomcat8",
"gid": "tomcat8",
"webappsPath": "/var/lib/tomcat8/webapps"
i am trying to use aggregate cli to deploy a ODK Aggregate server.
But in the logs of Catalina say that try to connect to Postgresql on the host: 127.0.0.1
Look in the next PATH "ROOT/WEB-INF/classes/jdbc.properties" i found this:
jdbc.driverClassName=org.postgresql.Driver
jdbc.resourceName=jdbc/odk_aggregate
jdbc.url=jdbc:postgresql://127.0.0.1/aggregate?autoDeserialize=true
jdbc.username=aggregate
jdbc.password=aggregate1
jdbc.schema=aggregate
aggregate cli ignore the config json in the setup, additionally dont create the config tables on the database
for fix this i change the jdbc.url item and work fine
Use aggregate-cli whit the config json that i created
The problem persist with other installations
