Dear All.
have created the aggregate using windows 7, but when i run the uploadAggregateToAppEngine i have this error:
Beginning server interaction for demarenia...
java.net.SocketException: Connection reset
Unable to update app: Connection reset
Please see the logs [C:\Users\Moha\AppData\Local\Temp\appcfg6885656704756507788.log] for further information.
---END-SCRIPT-FAILURE---
is there something wrong that i have done ?? my internet connection is working fine but I don't know where is the problem.
thank you all for your time
I recommend uninstalling Java and re-installing it on your Windows 7
system. It looks like there are errors earlier in the script relating to
your Java installation.
We test and use either: JRE 6
http://www.oracle.com/technetwork/java/javase/downloads/jre6downloads-1902815.html
or: JRE 7
On Sun, Jul 7, 2013 at 5:46 AM, wrote:
Dear All.
Please see the logs
