In
org.opendatakit.aggregate.client.widgets.EnumListBox
following method:
public T getSelectedValue() {
int selectedIndex = getSelectedIndex();
if (selectedIndex > -1) {
return (T) Enum.valueOf(classType, getValue(selectedIndex));
} else {
return null;
Compiler error:
The return type is incompatible with ListBox.getSelectedValue()
EnumListBox.java
/eclipse-aggregate-gae/src/org/opendatakit/aggregate/client/widgets
line 30
Java Problem
I have not changed any code, I'm just trying to compile Aggregate as is.
Seems like some issue with generics or compiler preference setting the
devteam uses that I need to mimic in my eclipse.
Could you offer any help to resolve this?
Jaideep
If it helps, I exported my Eclipse Java compiler preferences
#Sat May 02 15:52:41 IST 2015
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.7
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=enabled
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1.7
@org.eclipse.jdt.core=3.10.2.v20150120-1634
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.7
file_export_version=3.0
On Saturday, May 2, 2015 at 3:32:23 PM UTC+5:30, Jaideep Baphna, CFA wrote:
> In
> following method:
> } else {
> return null;
> *Compiler error:*
> EnumListBox.java
> line 30
> Java Problem
> Thanks
> Jaideep
Double-check that you have pulled the latest code. This sounds like an
earlier or intermediate check-in after upgrading to GWT 2.7.0. The latest
code should have this fixed (I created a new API to return T, and left
getSelectedValue as returning a String).
In
following method:
} else {
return null;
Compiler error:
EnumListBox.java
line 30
Java Problem
Jaideep
"ODK Developers" group.
Mitch, Thanks!
It must have been a pull of intermediate check-in. I checked-out all code
again and now it compiles.
The CONFIGURE.TXT instructions are super valuable. The dev setup
and technology stack is quite intimidating. BUT I just intend to skin
Aggregate for now. Please could you point out areas we should focus on.
Thanks again
Jaideep
This describes the package naming conventions:
https://code.google.com/p/opendatakit/wiki/AggregateSourceCodeOverview
On Sat, May 2, 2015 at 8:34 PM, Jaideep Baphna, CFA wrote:
Mitch, Thanks!
Thanks again
Jaideep
