Hello,
I have been trying to set up Aggregate 1.4.8 for AppEngine but the setup wizard is freezing when I try to enter my application ID (not responding, after only one keystroke in this field). Even before I type into this field, the check-box "Yes, a Master/Slave application id is being (was) migrated to this application id" flickers. This has occurred several times, even after a computer reboot. Any advice?
CS
I have never seen this behavior.
Try running the wizard on a bigger/different computer.
It sounds like a computer memory-size problem.
On Mon, Apr 18, 2016 at 2:28 PM, wrote:Hello,
CS--
Thanks for this recommendation, I did get it set up without any problem on another PC. (Strange that my really nice 3-month-old laptop didn't work but a 5-yr-old one did...)
What operating system (and version) was on the problematic PC?
On Fri, Apr 22, 2016 at 10:44 AM, wrote:Thanks for this recommendation, I did get it set up without any problem on
a 5-yr-old one did...)--
The problematic PC is a Lenovo Yoga 900 with operating system Windows 10 Home (version 1511). Thanks for helping me resolve this problem, Mitch!
CS
