I have installed aggregate virtual machine. But my subordinates are not
able to download forms form server url provided by virtual machine.
Dr.Raj Sutariya
Dr.Raj Sutariya
Hi Raj,
The devices have to be on the same IP network as the VM.
Thank for reply.
But what if my subordinate is not in same network IP?
Because with app engine settings anyone is able to download form,But the
same is not possible for virtual machine.
Please help
Hi guys,
Is the preconfigured VM ok to work in production? Or is it more advisable
to do a fresh install using the installer?
regards
Dudley
Hi there,
I am having the same problem as Dr.RAJ,
though I connected the server and the Android device to the same network.
I am receiving the following error:
Form Listing Failed. Error:
android.system.ErrnoException:
isConnected failed:
ECONNREFUSED (Connection
Refused) while accessing https://
*myipaddress//formlist *
Could you please help me?
Which password and username should I set in in General Settings? I am using
credential from different users I set in "Site Admin".
Thank you for your time.
Vittorio
Hi Raj,
You have to make your VM publicly accessible on the Internet with a
static IP or fully-qualified domain name. Doing this requires a fair
amount of technical skill and we instead recommend you install ODK
Aggregate on App Engine.
On Sat, Jul 4, 2015 at 7:08 AM, Dr.RAJ rajbpvs@gmail.com wrote:
Thank for reply.
same is not possible for virtual machine.Please help
Though if I go to http://myipaddress//formList in a browser it does
download the form I updated in Aggregate.
Hi Vittorio,
The VM doesn't have SSL. Use http and not https.
Hi Raj,
Aggregate on App Engine.Yaw
setup, professional support, and software development for ODK.Thank for reply.
Hi Yaw, how to install the ODK aggreggate in App engine, where to click in the app engine? can u provide any screenshots? or we shoukld create a project in app engine? thank you
Thanks a lot!
Pls sir if i send mu finilized form is showing me connection closed by peer
Sir i need your support
Safiya
See http://opendatakit.org/use/aggregate/
On Saturday, July 4, 2015 at 6:16:43 PM UTC+2, Yaw Anokwa wrote:
Hi Raj,
setup, professional support, and software development for ODK.On Sat, Jul 4, 2015 at 7:08 AM, Dr.RAJ rajbpvs@gmail.com wrote:
Thank for reply.
the
Groups
an
For more options, visit https://groups.google.com/d/optout.Hi Yaw, how to install the ODK aggreggate in App engine, where to click in
project in app engine? thank you--
Safiya,
If you are using the VM, make sure your device is on the same network
as the VM. Also, make sure you are using HTTP and not HTTPS in the
URL.
