The issue is with the connectivity to Aggregate VM. The VM is running on Oracle VirtualBox. When installing the VM I have followed the steps mentioned in the setting up documentation in https://docs.opendatakit.org/aggregate-vm/#setting-up-the-vm.
I have successfully setup and configured the VM. Initially I was able to connect to the Aggregate VM
- from the browser on host computer,
- from the Briefcase,
- was able to get blank forms and send finalazed forms using ODK Collect on the tab.
After about 2 days of usage the connectivity was intermittent, ie. the connection to Aggregate VM was working sometimes but some other times cannot able to connect. When I used the IP address that is shown by the AggregateVM, the browser shows the message "This site can't be reached" "ERR_CONNECTION_TIMED_OUT". When I used the alternate IP, the browser shows the "Awaiting Redirect" and throws an "ERR_CONNECTION_TIMED_OUT" error. In the Network tab of the Chrome browser Inspect, the status shows Aggregate.html loading as failed.
I tried all the Aggregate VM versions starting from version 1.7.0 upto 2.0.0, but the connectivity issue remains the same with all the versions.
-Core i5 desktop with Windows 10 Pro
-AggregateVM 2.0.0 on VirtualBox
-ODK-Briefcase-v1.13.1
-ODK Collect v1.19.0
After going through the support forum with the connectivity issues topics some of the following reasons were mentioned
-local netork setup
-internet connectivity
-VM not configured properly
To avoid all the complications I used only one desktop with a dedicated wifi hotspot but still I could not connect to the VM.
