Are there any instructions available for setting up Aggregate 1.0 to
work with PostgreSQL? We wouldn't mind helping to test it out...
Hi Tyler,
Are you a Eclipse/Java software developer? Or just savvy about installing
web apps? Or neither?
On Mon, Mar 14, 2011 at 9:42 AM, Tyler Erickson wrote:Are there any instructions available for setting up Aggregate 1.0 to
work with PostgreSQL? We wouldn't mind helping to test it out...--
I'm not a java developer. I use eclipse, but for Python development
(PyDev). My java web app installation experience usually involves dropping
war files into Tomcat, and submitting log traces when something goes wrong.
- Tyler
On Mon, Mar 14, 2011 at 1:31 PM, Mitch Sundt wrote:Hi Tyler,
web apps? Or neither?Mitch
http://www.OpenDataKit.org
mitchellsundt@gmail.com--
Great.
Set up a system with the latest JDK, Tomcat and Postgresql installed. Are
you a Windows or Linux or Mac user?
I'll write up the other steps in a bit. I'm working on a check-in, and will
provide you with a war file after I get that done.
Since we don't have a Postgres installer yet, you'll need to manually
configure the database, and also manually alter some configuration files,
then update a jar in the war file I give you. Once that is done, you can
drop the modified war into tomcat, and you should be good to go. Tedious
and less complex than it sounds.
On Mon, Mar 14, 2011 at 12:52 PM, Tyler Erickson wrote:I'm not a java developer. I use eclipse, but for Python development
- Tyler
On Mon, Mar 14, 2011 at 1:31 PM, Mitch Sundt msundt@cs.washington.eduwrote:
Hi Tyler,
I develop on ubuntu linux, and I am comfortable installing and configuring
postgresql.
Do you use postgis to store the spatial data types?
Great.
you a Windows or Linux or Mac user?I'll write up the other steps in a bit. I'm working on a check-in, and
will
provide you with a war file after I get that done.Since we don't have a Postgres installer yet, you'll need to manually
and less complex than it sounds.Mitch
droppingwar files into Tomcat, and submitting log traces when something goes
wrong.
- Tyler
Hi Tyler,
installing
On Mar 14, 2011 5:09 PM, "Mitch Sundt" wrote: > On Mon, Mar 14, 2011 at 12:52 PM, Tyler Erickson > On Mon, Mar 14, 2011 at 1:31 PM, Mitch Sundt >> web apps? Or neither? >>> >>> Mitch >>> >>> >>> On Mon, Mar 14, 2011 at 9:42 AM, Tyler Erickson >> >>>> Are there any instructions available for setting up Aggregate 1.0 to >>>> work with PostgreSQL? We wouldn't mind helping to test it out... >>>> >>>> -- >>>> Post: opendatakit@googlegroups.com >>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>> >>> >>> >>> -- >>> Mitch Sundt >>> Software Engineer >>> http://www.OpenDataKit.org >>> University of Washington >>> mitchellsundt@gmail.com >>> >>> -- >>> Post: opendatakit@googlegroups.com >>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> > > > > -- > Mitch Sundt > Software Engineer > http://www.OpenDataKit.org > University of Washington > mitchellsundt@gmail.com > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=enI got this all working with Postgres once, struggled with the use of
Google Accounts for login though, but finally did get it working.
Would love to have instructions. AFAIK, postgis is not used by
default, I added a trigger to create a postgis point from the lat and
lon columns on insert. I had started looking at how to make ODK a
GeoServer community module so we could get WMS/WFS pretty easily, but
never got beyond the drawing board.
Jeff
On Mon, Mar 14, 2011 at 4:37 PM, Tyler Erickson wrote: > I develop on ubuntu linux, and I am comfortable installing and configuring > postgresql. > > Do you use postgis to store the spatial data types? > > On Mar 14, 2011 5:09 PM, "Mitch Sundt" wrote: >> Great. >> >> Set up a system with the latest JDK, Tomcat and Postgresql installed. Are >> you a Windows or Linux or Mac user? >> >> I'll write up the other steps in a bit. I'm working on a check-in, and >> will >> provide you with a war file after I get that done. >> >> Since we don't have a Postgres installer yet, you'll need to manually >> configure the database, and also manually alter some configuration files, >> then update a jar in the war file I give you. Once that is done, you can >> drop the modified war into tomcat, and you should be good to go. Tedious >> and less complex than it sounds. >> >> Mitch >> >> On Mon, Mar 14, 2011 at 12:52 PM, Tyler Erickson wrote: >> >>> I'm not a java developer. I use eclipse, but for Python development >>> (PyDev). My java web app installation experience usually involves >>> dropping >>> war files into Tomcat, and submitting log traces when something goes >>> wrong. >>> >>> - Tyler >>> >>> >>> On Mon, Mar 14, 2011 at 1:31 PM, Mitch Sundt wrote: >>> >>>> Hi Tyler, >>>> >>>> Are you a Eclipse/Java software developer? Or just savvy about >>>> installing >>>> web apps? Or neither? >>>> >>>> Mitch >>>> >>>> >>>> On Mon, Mar 14, 2011 at 9:42 AM, Tyler Erickson wrote: >>>> >>>>> Are there any instructions available for setting up Aggregate 1.0 to >>>>> work with PostgreSQL? We wouldn't mind helping to test it out... >>>>> >>>>> -- >>>>> Post: opendatakit@googlegroups.com >>>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>>> >>>> >>>> >>>> >>>> -- >>>> Mitch Sundt >>>> Software Engineer >>>> http://www.OpenDataKit.org >>>> University of Washington >>>> mitchellsundt@gmail.com >>>> >>>> -- >>>> Post: opendatakit@googlegroups.com >>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>> >>> -- >>> Post: opendatakit@googlegroups.com >>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >> >> >> >> -- >> Mitch Sundt >> Software Engineer >> http://www.OpenDataKit.org >> University of Washington >> mitchellsundt@gmail.com >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >Correct, we don't use postgis. We store geopoints as 4 columns of lat,
long, altitude, accuracy.
Hopefully a view could be defined on top of our table that would present the
postgis datatypes?
I'll start work on the configuration steps this afternoon...
On Mon, Mar 14, 2011 at 6:33 PM, Jeffrey Johnson wrote:I got this all working with Postgres once, struggled with the use of
never got beyond the drawing board.Jeff
configuring
postgresql.Do you use postgis to store the spatial data types?
On Mar 14, 2011 5:09 PM, "Mitch Sundt" msundt@cs.washington.edu wrote:
Great.
Areyou a Windows or Linux or Mac user?
will
files,then update a jar in the war file I give you. Once that is done, you can
dropping
wrong.
- Tyler
Hi Tyler,
installing
Here is information on what to do:
http://code.google.com/p/opendatakit/wiki/AggregatePostgresqlInstall
On Tue, Mar 15, 2011 at 11:59 AM, Mitch Sundt wrote:Correct, we don't use postgis. We store geopoints as 4 columns of lat,
long, altitude, accuracy.Hopefully a view could be defined on top of our table that would present
the postgis datatypes?I'll start work on the configuration steps this afternoon...
configuring
Great.
will
candrop the modified war into tomcat, and you should be good to go.
Tediousand less complex than it sounds.
dropping
wrong.
- Tyler
Hi Tyler,
installing
