Agregate login problems
Hi List,
I deployed ODK on Tomcat and PostgreSQL on a cloud hosted server.
Everything see,s to be running fine and I am presented with a login screen
but neither the "Sign in with Agregate password" nor the "Sign in with
Google" options allow me to log in. I wasn't propted to provide a password
during the installation process, only my gmail address.
In both cases I get a tomcat error stating:
HTTP Status 401 - Authentication Failed: Log in failed - identity could not
be verified
Is there any way to manually set a login string or any other workaround?
Thanks very much
Lawrence
Correction. When using the "Sign in with Agregate password " option, the
error is:
HTTP Status 401 - Username xxxxx@gmail.com not found
··· On Friday, 16 August 2013 16:29:44 UTC+2, Lawrence Strydom wrote: > > Hi List, > > I deployed ODK on Tomcat and PostgreSQL on a cloud hosted server. > Everything see,s to be running fine and I am presented with a login screen > but neither the "Sign in with Agregate password" nor the "Sign in with > Google" options allow me to log in. I wasn't propted to provide a password > during the installation process, only my gmail address. > > In both cases I get a tomcat error stating: > HTTP Status 401 - Authentication Failed: Log in failed - identity could > not be verified > > > Is there any way to manually set a login string or any other workaround? > > > Thanks very much > > > Lawrence >
It is always advisable to first gain familiarity with the tools by
deploying them to Google AppEngine, then move on to setting up your own
server.
The correct initial login option is 'Sign in with Google'. You then must
specify the gmail account that you gave during the running of the installer.
If you have already tried 'Sign in with Aggregate password', you must
completely close and exit your browser and re-open it, then go to the page
and select the 'Sign in with Google' option.
Once signed in, you can go to the Site Admin page and create Aggregate
usernames, and assign them passwords, and then use those usernames and
passwords.
error is:
Hi List,
not be verified
Thanks very much
Lawrence
Hi Mitch,
Thanks for your help.
I restarted not only my browser but my PC itself but I still get the error:
be verified
when signing in with my google account. I know it's the right account cause
I am posting here using the same login.
I have deployed and used Agregate on App engine before but decided to
deploy it on my own server as I need direct access to the database in order
to run reporting and BI tools against the data.
Is there any way other than the superUserEMail entry in the log file where
I can check what account is being used?
Lawrence
··· On Friday, 16 August 2013 18:54:49 UTC+2, Mitch Sundt wrote: > > It is always advisable to first gain familiarity with the tools by > deploying them to Google AppEngine, then move on to setting up your own > server. > > > The correct initial login option is 'Sign in with Google'. You then must > specify the gmail account that you gave during the running of the installer. > > If you have already tried 'Sign in with Aggregate password', you must > completely close and exit your browser and re-open it, then go to the page > and select the 'Sign in with Google' option. > > Once signed in, you can go to the Site Admin page and create Aggregate > usernames, and assign them passwords, and then use those usernames and > passwords. > > Mitch > > > > On Fri, Aug 16, 2013 at 7:36 AM, Lawrence Strydom <qho...@gmail.com wrote: > >> >> Correction. When using the "Sign in with Agregate password " option, the >> error is: >> >> HTTP Status 401 - Username xx...@gmail.com not found >> Thanks >> >> >> On Friday, 16 August 2013 16:29:44 UTC+2, Lawrence Strydom wrote: >>> >>> Hi List, >>> >>> I deployed ODK on Tomcat and PostgreSQL on a cloud hosted server. >>> Everything see,s to be running fine and I am presented with a login screen >>> but neither the "Sign in with Agregate password" nor the "Sign in with >>> Google" options allow me to log in. I wasn't propted to provide a password >>> during the installation process, only my gmail address. >>> >>> In both cases I get a tomcat error stating: >>> HTTP Status 401 - Authentication Failed: Log in failed - identity could >>> not be verified >>> >>> >>> Is there any way to manually set a login string or any other workaround? >>> >>> >>> Thanks very much >>> >>> >>> Lawrence >>> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/groups/opt_out. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >
It would be in the _registered_users table, under the OPENID_EMAIL column.
Note that your e-mail name must exactly match what Google shows as that
e-mail name on your Gmail page (top right corner). I.e., no changes in
capitalization or extra periods, etc.
··· On Sat, Aug 17, 2013 at 5:45 AM, Lawrence Strydom wrote:
Hi Mitch,
not be verified
cause I am posting here using the same login.
Lawrence
server.
passwords.
error is:
Hi List,
not be verified
Thanks very much
Lawrence
Unsubscribe: opendatakit...@**googlegroups.com
Groups "ODK Community" group.
an email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
mitche...@gmail.com
