We are collecting data on a 0.9.8 server running on the app engine.
As has been discussed, the complete dataset there is not available for
download (the server only exports the first 990 to a csv). Therefore,
I have been forced to use briefcase to move the data from 0.9.8 to
another app engine database running 1.0 ODK.
First, is there any way I can stop needing to do this?
Next, I get the following errors on a few records. Does it mean that
this records were not transfered and therefore, lost?
Thanks!
Alex
UPLOAD FAILED: Submission upload failed. Detailed error: Unexpected
exception: Original submission file's submissionDate does not match
that on server! C:\Users\Administrator\Desktop\ODK_scrap\scratch\PH
Lab v1\instances\md5ffdc2e0f64dc4c44427fae11344da678\submission.xml
Partially successful upload...
First, if you are staying with 0.9.x, then you can use the Briefcase applet
available from the "Briefcase" link on that server to download your entire
server into a csv file. It will get everything.
Obviously, until you migrate all your clients to point to Aggregate 1.x, you
will continue to need to transfer your data periodically to be able to
access it from 1.x.
Second, always check that you're using the latest software versions.
The date/time issue you are experiencing was fixed by bringing all
systems to these versions (you must upgrade them all):
These have changes to address the datetime issue you are experiencing.
Thanks!
Alex
Oh, I didn't realize that you could use briefcase to save the csv.
Thanks so much, Mitch!
Alex
> access it from 1.x.
> Aggregate 0.9.8.1
> Aggregate 1.0.1
> Briefcase 1.0 Beta 2.1
> Mitch
> > Thanks!
> > Alex
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> University of Washington
> mitchellsu...@gmail.com
