I experienced the "Network did not assign this VM an IP" issue and resolved
it by logging into the VM as root and resetting the network interfaces like
this:
rm /etc/udev/rules.d/70-persistent-net.rules
In my case the issue was that eth0 was somehow assigned as eth2 (you can
check this with ip link ). Removing the rules with the command above and
rebooting fixed that.
No problems converting the VirtualBox VM as a Parallels VM (simply open the
VM in Parallels to start the conversion).
Cheers,
Martijn
On Thursday, August 1, 2013 7:59:33 PM UTC-6, Yaw Anokwa wrote:
> Palak,
> Please don't post to both lists.
> The VM works without Internet connectivity, but you need IP
> connectivity (usually WiFi) to connect ODK Collect to ODK Aggregate
> running in VM.
> Thanks,
> Yaw
> Need ODK services? Go to http://nafundi.com for form design, data
> cleaning, custom reporting, and software development for ODK.
> On Thu, Aug 1, 2013 at 2:05 PM, Palak Darji <palak...@gmail.com> wrote:
> > That's so easy to install !
> > Great.... But one thing, i don't understand is this sentence: " works
> well
> > without Internet connectivity"as Yaw said.
> > How can i use it without any internet connectivity? At least mine's not
> > worked.. So i need your little help to understand it n to solve it...
> > Palak
> Groups
> > "ODK Community" group.
> an
> > For more options, visit https://groups.google.com/groups/opt_out.
The ODK Survey public alpha uses exactly the same APIs as ODK Collect, so,
yes, 1.2 and 1.3 servers, and the VM all work. That said, ODK Survey
requires the files laid out and structured as they are in the https://opendatakit-2.appspot.com instance.
I don't know what ODK Survey does if you download an ODK Collect form. It
hopefully discards it without crashing...
On Tue, Feb 5, 2013 at 9:21 AM, Neil Hendrick wrote:
thanks, Mitch. I'll be sure to check back with any results from testing.
☞§※☼:airplane:
~Neil
Connecting to the database goes beyond the use-case we are targeting
for our initial release, but until we provide an easier way, you can
treat the VM like any ordinary server. It's Tomcat backed with MySQL,
so use the login information provided in the readme.txt to login and
query the database. Alternatively, you can dump the form data using
ODK Briefcase.
We will try to include some more documentation for advanced use-cases
in the next release.
On Wed, Feb 6, 2013 at 5:03 AM, avadhani ramakrishna wrote:
> Hello Yaw,
> I have downloaded and installed ODK Aggregate Virtual machine(VM) in my
> machine and everything is working fine. I have submitted two forms to the VM
> through ODK Briefcase and form data is submitted successfully. I need to
> verify the form data in Database in VM. How can i check the submitted form
> data in VM? Please help me.
> Thanks
> Avadhani Ramakrishna.
> On Tuesday, 5 February 2013 14:12:59 UTC+5:30, Chan Choth Puth wrote:
>> Hi Martijn,
>> It uses VirtualBox and it is easy to deploy this VM locally by extracting
>> the file to the server. It is copy and paste actually.
>> Cheers,
>> Chan Choth
>> On Tuesday, February 5, 2013 7:49:30 AM UTC+7, Martijn van de Rijdt wrote:
>>> Hi Yaw,
>>> That's very cool! Thanks for making this available. Could you perhaps
>>> explain a little about how this VM is deployed locally? Is it using
>>> VirtualBox?
>>> Cheers,
>>> Martijn
>>> On Monday, February 4, 2013 1:16:33 PM UTC-7, Yaw Anokwa wrote:
>>>> As you might already know, ODK Aggregate allows users to download
>>>> blank forms and upload completed forms. Aggregate also enables users
>>>> to visualize, export and publish form data.
>>>> Aggregate can be installed on a local server or in the cloud, but many
>>>> users find local servers hard to configure or find the cloud insecure.
>>>> At Nafundi, we think we have found a better way through the ODK
>>>> Aggregate VM (http://gum.co/odk-aggregate-vm).
>>>> The ODK Aggregate VM (virtual machine) solves many of the challenges
>>>> of deployment because it is a fully-configured install of Aggregate
>>>> that you can run on any computer (desktop, laptop, server). The VM
>>>> requires very little setup, works well without Internet connectivity,
>>>> and gives you complete control over your data collection campaign.
>>>> If you are new to ODK, the VM is a great way to get started with
>>>> Aggregate v1.3. In a few clicks, you can have the entire server
>>>> running locally on your computer.
>>>> If you are an implementer, the VM is the easiest way to get the power
>>>> and flexibility of Aggregate without Internet access. You can even
>>>> connect your reporting tools to the underlying MySQL database.
>>>> If you are a developer, the VM is a perfect test environment. Take
>>>> snapshots before you try something totally new. If something goes
>>>> wrong, revert easily.
>>>> Regardless of who you are, we think the ODK Aggregate VM is a great
>>>> way to run Aggregate v1.3. Try it today at
>>>> http://gum.co/odk-aggregate-vm!
>>>> Yaw
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
Hi and thank you all for this information.
Sorry about the late reply but I have been distracted by some projects and
didn't get back to this right away.
I used the information you provided and now it works! (Duh... I should have
checked this myself.)
I can log into Mirth and add a channel using Database Reader, MySQL
and jdbc:mysql://localhost/aggregate for the URL. This gives me access to
the ODK Aggregate tables to create a channel.
Now that I have this working, I have a VM which includes your ODK Aggregate
and also Mirth Connect running.
I'd be happy to share this with anyone who is interested. Unfortunately
the VM .ova file has grown to 830MB and zipping it doesn't help much. I'll
put it together with some notes on what I have done to create it and put it
up for sharing.
Thanks again for all of your help.
.Mark
On Thu, Feb 14, 2013 at 10:31 AM, Mitch S wrote:
Generally, you want to use localhost in the jdbc setup, as the IP address
192.168.0.43 is dynamically allocated and is therefore brittle.
Note that users other than root must be granted access to databases. You
are perhaps missing that grant?
The database is called 'aggregate'. To confirm this, log into the VM's
command line with the credentials in the readme. Then login using
'mysql -u root -p' and run 'show databases' to get a list of
databases.
I'm also pretty sure MySQL doesn't allow connections outside of
localhost so you might have to configure your mysql user to allow
those connections (less secure) or connect over SSH (more secure).
Need ODK help? Go to http://nafundi.com for custom development,
professional support, form design, implementation advice, and user
training for ODK.
On Wed, Feb 13, 2013 at 2:04 PM, Mark Spohr mhspohr@gmail.com wrote:
Thanks so much for putting this together.
I've installed the VM and am running it.
I wanted to use Mirth along with ODK so I installed Mirth (and Java6)
in the
VM also.
I can get both ODK Aggregate and Mirth to run but I'm having problems
setting up a channel in Mirth.
I am following the instructions here: http://code.google.com/p/crossriver-openhds/wiki/CreateMirthChannel
But, I can't connect to the database...
I have used both jdbc:mysql://localhost/odk_prod and
jdbc:mysql://192.168.0.43/odk_prod as the URL for the database,
assuming
that the port is the standard 3306 for ODK MySQL... is this correct?
Once (if) I get this working, I'll send you the new VM.
Good tip, Martijn. I'll add it to the next build's readme.
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
On Wed, Oct 30, 2013 at 1:46 PM, Martijn van de Rijdt martijn@enketo.org wrote:
In case anybody benefits from this.
this:
Cheers,
Martijn
Palak,
running in VM.
well
I'm experiencing a similar issue of "Network did not assign this VM an IP".
I followed the steps in the README file but switching to NAT and port
forwarding to 80 didn't seem to work for me and perhaps what you did might.
I'm wondering if you wouldn't mind breaking down how you resolved it in a
few more steps? I.e. how to log into the VM as root via command line and
any additional steps you took.
Thanks for your help.
Andrew
> resolved it by logging into the VM as root and resetting the network
> interfaces like this:
> check this with *ip link )*. Removing the rules with the command above
> and rebooting fixed that.
> the VM in Parallels to start the conversion).
> Cheers,
> Martijn
>> Palak,
>> running in VM.
>> Thanks,
>> Yaw
>> well
>> > Palak
>> Groups
>> an
>> > email to opendatakit...@googlegroups.com.
Once you reach the command line and type: "ip link" to show the network
interfaces. If you don't see eth0 listed, then you're probably experiencing
the same issue I had. This can be resolved by resetting the network
interfaces (i.e. removing a file so that it will be rebuilt upon next
boot): "rm /etc/udev/rules.d/70-persistent-net.rules".
After that: "reboot".
Cheers,
Martijn
On Tue, Nov 5, 2013 at 4:04 AM, Andrew Pham wrote:
Hi Martijn,
IP". I followed the steps in the README file but switching to NAT and port
Andrew
Cheers,
Martijn
Palak,
running in VM.
well
not
I'm still having some trouble accessing the command line where I'm suppose
to log in with root/aggregate.So far, I've been only able to get to Virtual
Box on the command line. Did you access the vm through "vboxmanage" or am I
going down the wrong path? If anyone can help walk me through the steps of
getting to the root/aggregate login would be greatly appreciated. Then I
assume after that I can enter "ip link" to pull up the network interfaces.
On Tuesday, November 5, 2013 9:52:05 PM UTC+6, Martijn van de Rijdt wrote:
> Hi Andrew,
> I'm not an expert but, this is a good resource:
> http://chris.dziemborowicz.com/blog/2010/07/25/fix-missing-eth0-when-cloning-ubuntu-vmware-virtual-machines/
> Cheers,
> Martijn
> On Tue, Nov 5, 2013 at 4:04 AM, Andrew Pham <andrew....@gmail.com wrote:
>> Hi Martijn,
>> Andrew
>>> rm /etc/udev/rules.d/70-**persistent-net.rules
>>> Cheers,
>>> Martijn
You can login inside the virtual machine after it has finished booting
(takes a long time if you have the network issue). You'll see a screen like
this.
On Wed, Nov 6, 2013 at 1:54 AM, Andrew Pham wrote:
Thanks for your quick response Martijn!
a few more steps? I.e. how to log into the VM as root via command line and
Andrew
can check this with ip link ). Removing the rules with the command
above and rebooting fixed that.
Wow, that was simple. Thanks again for your help and patience.
I've got the VM up and running. This is going to work wonders with ODK Scan
since using it with ODK Aggregate on the app engine eats up the read and
write operations pretty quickly.
Andrew
On Thursday, November 7, 2013 2:49:52 AM UTC+6, Martijn van de Rijdt wrote:
> Hi Andrew,
> this.
>> suppose to log in with root/aggregate.So far, I've been only able to get to
>> Virtual Box on the command line. Did you access the vm through "vboxmanage"
>> or am I going down the wrong path? If anyone can help walk me through the
>> steps of getting to the root/aggregate login would be greatly appreciated.
>> Then I assume after that I can enter "ip link" to pull up the network
>> interfaces.
>> As for the eth0 error, here's a screenshot from the vm showing "device
>> not found".
>> Best,
>> Andrew
>>> Hi Andrew,
>>> I'm not an expert but, this is a good resource: http://chris.
>>> Cheers,
>>> Martijn
>>>> Hi Martijn,
>>>> Andrew
>>>>> can check this with *ip link )*. Removing the rules with the command
>>>>> open the VM in Parallels to start the conversion).
>>>>> Cheers,
>>>>> Martijn
>> You received this message because you are subscribed to a topic in the
>> Google Groups "ODK Community" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/opendatakit/5Su4TT2s3OM/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
> Enketo | LinkedIn |
> GitHub
