I am posting this question just to get an idea on how to integrate ODK Aggregate data with other web application (possibly developed with php/mysql). i.e. I will develop a web application with three or forms similar to ODK forms and to allow users access the web application interface from browser and to populate data to the ODK aggregate
Is there any mechanism or to begin
I have no idea where to begin , Please reply to the post if you have any idea about
Also consider using and contributing to Enketo-corehttps://github.com/MartijnR/enketo-coreif you'd like to evaluate form logic inside the browser, using javascript,
without server communication (does not use any of the OpenRosa libraries).
This core library is meant to be used as a building block for developers to
develop ODK-compatible apps with. Note that it will undergo some major
modernization work in the next few months.
On Thursday, September 19, 2013 1:41:23 AM UTC-6, yonadre...@gmail.com wrote:
> Dear ODK developers,
> idea about
> Regard,
> Jonas
