Dear ODKers,
We've been running v1.0.6 production successfully for some time, then
earlier today we started receiving errors trying to log in to Aggregate.
The error message is the generic one:
AppEngine Application Problem
A problem has occurred that prevents your AppEngine application from
responding. Your application may have exceeded its per-minute or daily
usage quotas.
Please visit your application dashboard at Google AppEngine. The Billing
Status section will indicate what daily or per-minute usage limits your
application has exceeded.
If your application's usage limits have not been exceeded, then look for
performance issues within Google AppEngine cloud services. From your
application dashboard, click on the the System Status link on the left
sidebar under the Resources heading. This will report problems with Google
If neither of those indicate any problems, then your application's Logs
may; these are reachable from the dashboard via the Logs link on the left
sidebar under the Main heading.
Following the advice above and elsewhere, we checked the logs. We are
nowhere near usage limits, but the problem appears to be that instance
start-up was taking too long and getting cut off:
"com.google.apphosting.api.DeadlineExceededException: This request
(51d9048e2f64ca86) started at 2012/06/04 17:55:25.466 UTC and was still
executing at 2012/06/04 17:56:24.910 UTC" (full log section below). This
happened repeatedly for one evening and then during the next morning, then
suddenly we started being able to access Aggregate again.
We're back online for the moment, but I'm worried about this cropping up
again and causing problems for our surveyors, etc. Is there anything that I
can do to make sure start-up doesn't take too long?
Chris
FROM THE APPENGINE LOG:
[ IP ADDRESS EDITED OUT ] - - [04/Jun/2012:10:56:25 -0700] "GET
/Aggregate.html HTTP/1.1" 500 0 - "Mozilla/5.0 (Windows NT 6.1)
AppleWebKit/536.5 (KHTML, like Gecko) Chrome/19.0.1084.52 Safari/536.5" "[
NAME EDITED OUT ].appspot.com" ms=62561 cpu_ms=10267 api_cpu_ms=0
cpm_usd=0.285243 loading_request=1 exit_code=104
instance=00c61b117caae31554c15db27a72f4c7c71ec28b
I 2012-06-04 10:55:52.210
javax.servlet.ServletContext log: Initializing Spring root
WebApplicationContext
I 2012-06-04 10:55:52.213
org.springframework.web.context.ContextLoader
initWebApplicationContext: Root WebApplicationContext: initialization
started
I 2012-06-04 10:55:57.902
org.springframework.context.support.AbstractApplicationContext
prepareRefresh: Refreshing Root WebApplicationContext: startup date [Mon
Jun 04 17:55:57 UTC 2012]; root of context hierarchy
I 2012-06-04 10:56:03.559
org.springframework.beans.factory.xml.XmlBeanDefinitionReader
loadBeanDefinitions: Loading XML bean definitions from class path resource
[odk-settings.xml]
I 2012-06-04 10:56:12.781
loadBeanDefinitions: Loading XML bean definitions from ServletContext
resource [/WEB-INF/applicationContext-security.xml]
I 2012-06-04 10:56:13.501
[odk-security-settings.xml]
I 2012-06-04 10:56:13.572
[odk-common-security-settings.xml]
I 2012-06-04 10:56:13.862
org.springframework.security.config.SecurityNamespaceHandler <init>:
Couldn't determine package version information.
I 2012-06-04 10:56:14.805
org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser
parseInterceptUrlsForFilterInvocationRequestMap: Creating access control
expression attribute 'true' for /_ah/**
expression attribute 'hasRole('ROLE_USER') or
hasRole('ROLE_SITE_ACCESS_ADMIN')' for /Aggregate.html
expression attribute 'hasRole('ROLE_USER')' for
/aggregateui/preferenceservice
I 2012-06-04 10:56:14.806
hasRole('ROLE_SITE_ACCESS_ADMIN')' for /aggregateui/securityservice
expression attribute 'hasRole('ROLE_DATA_VIEWER')' for
/aggregateui/filterservice
/aggregateui/submissionservice
/aggregateui/formservice
expression attribute 'hasRole('ROLE_DATA_OWNER')' for
/aggregateui/formadminservice
I 2012-06-04 10:56:14.807
/aggregateui/servicesadminservice
expression attribute 'hasRole('ROLE_SITE_ACCESS_ADMIN')' for
/aggregateui/securityadminservice
I 2012-06-04 10:56:14.814
expression attribute 'true' for /aggregateui/**
I 2012-06-04 10:56:14.815
expression attribute 'true' for /images/**
expression attribute 'true' for /javascript/**
expression attribute 'true' for /res/**
expression attribute 'true' for /stylesheets/**
I 2012-06-04 10:56:14.816
expression attribute 'true' for /access-denied.html
expression attribute 'true' for /over-quota.html
expression attribute 'true' for /robots.txt
expression attribute 'true' for /service-error.html
expression attribute 'true' for /AggregateUI.css
I 2012-06-04 10:56:14.817
expression attribute 'true' for /favicon.ico
expression attribute 'true' for /index.html
expression attribute 'true' for /logout.html
expression attribute 'true' for /odk_color.png
expression attribute 'true' for /openid_login.html
I 2012-06-04 10:56:14.818
expression attribute 'true' for /relogin.html
expression attribute 'isFullyAuthenticated() and hasRole('AUTH_LOCAL')' for
/local_login.html
I 2012-06-04 10:56:14.819
expression attribute 'hasRole('ROLE_DATA_COLLECTOR') or
hasRole('ROLE_DATA_VIEWER')' for /formList
hasRole('ROLE_DATA_VIEWER')' for /formXml
I 2012-06-04 10:56:14.820
hasRole('ROLE_DATA_OWNER')' for /submission
expression attribute 'hasRole('ROLE_DATA_OWNER')' for /formUpload
expression attribute 'hasRole('ROLE_DATA_OWNER')' for /upload
I 2012-06-04 10:56:14.821
hasRole('ROLE_DATA_VIEWER')' for /xformsDownload
hasRole('ROLE_DATA_VIEWER')' for /xformsList
hasRole('ROLE_DATA_VIEWER')' for /xformsManifest
expression attribute 'hasRole('ROLE_USER')' for /www/**
I 2012-06-04 10:56:14.822
expression attribute 'hasRole('ROLE_DATA_VIEWER') or
hasRole('ROLE_ATTACHMENT_VIEWER')' for /view/binaryData
expression attribute 'hasRole('ROLE_DATA_VIEWER')' for /view/**
expression attribute 'hasRole('ROLE_DATA_OWNER')' for /auth/**
expression attribute 'hasRole('ROLE_SITE_ACCESS_ADMIN')' for /ssl/**
expression attribute 'true' for /gae/**
expression attribute 'true' for /remote_api
I 2012-06-04 10:56:14.836
expression attribute 'isAnonymous()' for /**
W 2012-06-04 10:56:14.931
org.springframework.security.config.http.MatcherType fromElement:
'path-type' is deprecated. Please use 'request-matcher' instead.
W 2012-06-04 10:56:14.933
I 2012-06-04 10:56:22.281
org.springframework.core.io.support.PropertiesLoaderSupport
loadProperties: Loading properties file from class path resource
[security.properties]
I 2012-06-04 10:56:22.713
loadProperties: Loading properties file from ServletContext resource
[/WEB-INF/logging.properties]
I 2012-06-04 10:56:22.846
[jdbc.properties]
I 2012-06-04 10:56:22.855
I 2012-06-04 10:56:22.869
I 2012-06-04 10:56:23.149
org.springframework.beans.factory.support.DefaultListableBeanFactory
preInstantiateSingletons: Pre-instantiating singletons in
org.springframework.beans.factory.support.DefaultListableBeanFactory@1af7c57:
defining beans
[org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0,datastore,realm,user_service,worksheet_creator,form_delete,purge_submissions,upload_task,kml_task,csv_task,http_client_factory,image_util,startup,oob_user_fetcher,watchdog,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#1,openid_4_java_http_client_factory,basicAuthenticationMessageDigestPasswordEncoder,hierarchicalRoleRelationships,org.springframework.security.web.access.expression.DefaultWebSecurityExpressionHandler#0,securityPolicy,serverSpringSecurityFilterChain,channelProcessingFilter,channelDecisionManager,portMapper,portResolver,secureChannelProcessor,insecureChannelProcessor,securityContextPersistenceFilter,securityContextRepository,logoutFilter,requestCacheAwareFilter,securityContextHolderAwareFilter,sessionManagerFilter,exceptionTranslationFilter,delegatingAuthenticationEntryPoint,localExceptionTranslationFilter,anonymousFilter,anonymousProvider,basicAuthFilter,basicEntryPoint,basicAuthenticationProvider,basicLoginService,digestAuthFilter,digestEntryPoint,digestAuthenticationProvider,digestLoginService,openIdFilter,openIdEntryPoint,openIdUserDetailsService,openIdAuthenticationProvider,tokenUserDetailsService,oobAuthFilter,oobAuthenticationProvider,oauth2ResourceFilter,oauth2AuthenticationProvider,filterSecurityInterceptor,accessDecisionManager,webPrivilegeEvaluator,authenticationManager];
root of factory hierarchy
I 2012-06-04 10:56:25.051
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry
destroySingletons: Destroying singletons in
defining beans
E 2012-06-04 10:56:25.051
initWebApplicationContext: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'realm' defined in class path resource [odk-settings.xml]:
Initialization of bean failed; nested exception is
executing at 2012/06/04 17:56:24.910 UTC.
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at
org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:548)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:136)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:467)
at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at
com.google.apphosting.runtime.jetty.AppVersionHandlerMap.createHandler(AppVersionHandlerMap.java:202)
at
com.google.apphosting.runtime.jetty.AppVersionHandlerMap.getHandler(AppVersionHandlerMap.java:171)
at
com.google.apphosting.runtime.jetty.JettyServletEngineAdapter.serviceRequest(JettyServletEngineAdapter.java:123)
at
com.google.apphosting.runtime.JavaRuntime$RequestRunnable.run(JavaRuntime.java:477)
at
com.google.tracing.TraceContext$TraceContextRunnable.runInContext(TraceContext.java:449)
at
com.google.tracing.TraceContext$TraceContextRunnable$1.run(TraceContext.java:455)
at com.google.tracing.TraceContext.runInContext(TraceContext.java:695)
at
com.google.tracing.TraceContext$AbstractTraceContextCallback.runInInheritedContextNoUnref(TraceContext.java:333)
at
com.google.tracing.TraceContext$AbstractTraceContextCallback.runInInheritedContext(TraceContext.java:325)
at
com.google.tracing.TraceContext$TraceContextRunnable.run(TraceContext.java:453)
at
com.google.apphosting.runtime.ThreadGroupPool$PoolEntry.run(ThreadGroupPool.java:251)
at java.lang.Thread.run(Thread.java:679)
Caused by: com.google.apphosting.api.DeadlineExceededException: This
request (51d9048e2f64ca86) started at 2012/06/04 17:55:25.466 UTC and was
still executing at 2012/06/04 17:56:24.910 UTC.
at
com.google.appengine.runtime.Request.process-51d9048e2f64ca86(Request.java)
at java.util.zip.ZipFile.read(Native Method)
at java.util.zip.ZipFile.access$1200(ZipFile.java:57)
at java.util.zip.ZipFile$ZipFileInputStream.read(ZipFile.java:476)
at java.util.zip.ZipFile$1.fill(ZipFile.java:259)
at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:158)
at sun.misc.Resource.getBytes(Resource.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:273)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at
org.springframework.beans.PropertyEditorRegistrySupport.createDefaultEditors(PropertyEditorRegistrySupport.java:207)
at
org.springframework.beans.PropertyEditorRegistrySupport.getDefaultEditor(PropertyEditorRegistrySupport.java:180)
at
org.springframework.beans.TypeConverterDelegate.findDefaultEditor(TypeConverterDelegate.java:314)
at
org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:161)
at
org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:470)
at
org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:516)
at
org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:510)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1406)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1365)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 1 more
W 2012-06-04 10:56:25.062
Failed startup of context
com.google.apphosting.utils.jetty.RuntimeAppEngineWebAppContext@187275d{/,/base/data/home/apps/[
NAME EDITED OUT ]/1.358341606294558885}
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 1 more
W 2012-06-04 10:56:25.063
Nested in org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'realm' defined in class path resource
[odk-settings.xml]: Initialization of bean failed; nested exception is
executing at 2012/06/04 17:56:24.910 UTC.:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
C 2012-06-04 10:56:25.070
Uncaught exception from servlet
javax.servlet.UnavailableException: Initialization failed.
at
com.google.apphosting.runtime.jetty.AppVersionHandlerMap.createHandler(AppVersionHandlerMap.java:211)
at
at
at
at
at
at
at
at
at
I 2012-06-04 10:56:25.108
This request caused a new process to be started for your application,
and thus caused your application code to be loaded for the first time. This
request may thus take longer and use more CPU than a typical request for
your application.
W 2012-06-04 10:56:25.108
A problem was encountered with the process that handled this request,
causing it to exit. This is likely to cause a new process to be used for
the next request to your application. If you see this message frequently,
you may be throwing exceptions during the initialization of your
application. (Error code 104)
