"Application not installed"
Hi all!
I'm trying to load ODK Collect onto a bunch of Android phones provided by a local research company in Kenya. Even though I've checked the box to allow installation from unknown sources, I get the message "Application not installed" each time I try to install the downloaded app.
Any suggestions?
Thanks!
Laura
Hi Laura,
I'm assuming you downloaded ODK Collect 1.3 from
http://code.google.com/p/opendatakit and that you are running Android
2.1 or greater. If you are running less than Android 2.1, use ODK
Collect 1.1.7. If you have any ODK derivatives, uninstall them first
before installing ODK Collect. If the above fails, you should talk to
the folks you got the phones from.
ยทยทยท -- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.
On Mon, Jul 1, 2013 at 10:41 AM, laura.budzyna@gmail.com wrote:
Hi all!
Any suggestions?
Thanks!
Laura
