ASCII function?
I'm trying to program a 5 letter character code (with the last letter in the code serving as a "check digit"). In order to calculte the check digit based on a character code, I need to use an ascii function. Is there code or syntax for obtaining the ASCII code of a character variable in ODK?
In microsoft excel the algorithm works in 5 calculations shown below to verify the entered check digit:
EXAMPLE:
Barcode entered: FUHFK
Entered check digit (last letter): K
  1. RESULT1 =( (CODE(MID(FUHFK,1,1)) - 65)*1) + ((CODE(MID(FUHFK,2,1)) - 65)*3) + ((CODE(MID(FUHFK,3,1)) - 65)*5) + ((CODE(MID(FUHFK,4,1)) - 65) *7)
  2. RESULT2 = FLOOR((RESULT1/26),1) + MOD(RESULT1,26)
  3. RESULT3 =IF(RESULT2>25,INT(($RESULT2/26)) + MOD($RESULT2,26),RESULT2)
  4. RESULT4=ASC(65 + RESULT3)
  5. Calculated check digit = =CHAR(RESULT4)
No. This is probably best handled by writing a program to process the
string and return whether or not it is good.
See the launching a 3rd party app section under:
http://opendatakit.org/help/form-design/examples/#integer_prompts
And see the feature that allows you to pass additional arguments to that
app here: http://opendatakit.org/help/form-design/external-apps/
EXAMPLE:
