Good morning,
I went through many discussions and came about quite advance cases when it came to the use of indexed-repeat() and position(..).
Yet mine is quite simple, but could not find anything that directly relates to it. The need is to be applied within Excel.
I want to assign various values to a specific variable, named monRecordID.
Hence monRecordID = [1025, 1041, 3045, 8901]
Henceforth, within a repeat group, ${monRecordID} with its specific value (dependent on the iteration number) are later to be applied.
What I did within the choices-sheet:
list_name name
monRecordID 1025
monRecordID 1041
monRecordID 3045
monRecordID 8901
But I do not know how to recall it within the survey sheet?
I do not want to use "select_multiple monRecordID", as monRecordID is independent of the device user.
Is it correct to make a list within the choices-sheet?
If so, how can I recall it within the survey-sheet?
In short, how are various values assigned to a specific variable with the use of Excel?
Thank you for your support,
Peter
