Audio for contraint_message
Hi ODK Community,
Does anyone know if it's possible to record audio for a constraint message?
Context: The questionnaire I'm working on will be used by participants independently so all the questions are recorded (audio column). I'd still like there to be constraints on their answers e.g. if the constraint is that they have to enter a number between 1-6, and they enter 9, I'd like the constraint message to pop up saying e.g. "Try again." and for that to be accompanied by an audio that pops up saying "Try again."
Does anyone know if this is possible? Thank you.
L
Hi Lizzy,
Instead of using constraints, use read-only notes because those allow
recordings. Then make the note relevant if the number that is being
entered is invalid.
On Thu, Oct 1, 2015 at 2:39 PM, lizzybutton@gmail.com wrote:
Hi ODK Community,
L
Hi Yaw,
Thank you very much for this. I will give it a go!
Lizzy
··· On Thursday, 1 October 2015 13:04:39 UTC+2, Yaw Anokwa wrote: > > Hi Lizzy, > > Instead of using constraints, use read-only notes because those allow > recordings. Then make the note relevant if the number that is being > entered is invalid. > > Yaw > -- > Need ODK services? http://nafundi.com provides form design, server > setup, professional support, and software development for ODK. > > On Thu, Oct 1, 2015 at 2:39 PM, <lizzy...@gmail.com > wrote: > > Hi ODK Community, > > > > Does anyone know if it's possible to record audio for a constraint > message? > > > > Context: The questionnaire I'm working on will be used by participants > independently so all the questions are recorded (audio column). I'd still > like there to be constraints on their answers e.g. if the constraint is > that they have to enter a number between 1-6, and they enter 9, I'd like > the constraint message to pop up saying e.g. "Try again." and for that to > be accompanied by an audio that pops up saying "Try again." > > > > Does anyone know if this is possible? Thank you. > > > > L > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google > Groups "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send > an email to opendatakit...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. >
