Excuse me if this is posted somewhere but I can't find it with a basic
google search.
I have 1.1.7 installed and I'm told it supports authentication. But no
idea how to implement this on my custom aggregator. Can some one
please point me to API docs or some specification of how ODK does
auth? Thanks.
> google search.
> auth? Thanks.
google search.
auth? Thanks.
Hello,
I am new in ODK develepment and now I am implementing a custom aggregate. I have managed to implement the protocol in most of the parts but i have failed to impliment the Authentication part. I am using Java.
I get the pop up for entering username and password on the client but i failed to get the inputs values from the Servlets request.
On Tue, Jul 12, 2011 at 09:04, Thomas Smyth wrote:
> Fantastic. Thanks to you both. Does ODK support basic, digest, or both?
> On 12 July 2011 12:02, Thales A. Ceolin wrote:
>> Hello Thomas,
>> I just did it one hour ago.
>> I have read https://bitbucket.org/javarosa/javarosa/wiki/AuthorizationAPI
>> Regards,
>> Thales
>>> google search.
>>> auth? Thanks.
> Hello Thomas,
> Regards,
> Thales
>> google search.
>> auth? Thanks.
google search.
auth? Thanks.
The authentication is using Digest Auth, an (old) international standard.
On Thu, Mar 6, 2014 at 9:10 AM, wrote:
Hello,
Aggregate 1.0 will only support digest auth unless you hand-configure your
server configuration; you would also need to do some work in the "change
password" code to support setting the basic auth password (the client-side
Javascript is sending up nulls now).
On Tue, Jul 12, 2011 at 9:07 AM, Thales A. Ceolin wrote:
According to documentaion is both,
I don't know why, but I had to comment the digest part in package
org.odk.collect.android.utilities.Webutils.java
On Tue, Jul 12, 2011 at 12:59 PM, Thomas Smyth <thomas.smyth@gatech.edu wrote:
google search.
auth? Thanks.
