Does your server handle HEAD requests? If you can, you should add support
for those on the /submission url.
Upload should always be a HEAD request followed by a POST request. The HEAD
request allows the server to negotiate over to a secure channel (https)
before you send the POST. This ensures that form data is never sent
inadvertently in the clear due to a configuration error on the phone or in
the form's tag.
If your server supports HEAD requests, the authentication negotiation will
occur on the HEAD request. So you're not saving much by the preemptive
authentication (it doesn't hurt anything, but it isn't a big win with a HEAD
request).
Preemptive authentication is only useful for the basic authentication, which
it looks like you're using. Please note that with basic auth, you should
require HTTPS for all interactions between ODK Collect and your server, as
that is what ODK Collect assumes (e.g., even for /formList). You also
should have ODK Collect configured with https: URLs.
Out of the box, ODK Aggregate uses digest authentication, and that requires
a nonce from the server and therefore must be initiated by the server, so
preemptive authentication is impossible when communicating with vanilla ODK
Aggregate.
On Thu, Jul 28, 2011 at 8:56 AM, Thomas Smyth wrote:
I'm attaching a diff file with these patches for now. To recap:
Fixes two bugs:
eternal 'sending' screen on form upload
too many http requests on upload
And adds one feature
preemptive authentication (reducing further the number of http
requests on upload, so now there is only 1 POST on upload, the way it
should be!)
request).
Actually in 1.1.7RC1, the authentication negotiation (Basic auth, this
is) is occurring on EVERY request. So every request is doubled. Unless
I'm mistaken, this is how non-preemptive basic authentication works.
With the code I've added in that patch, only the HEAD request happens
twice. So this is quite a big savings as the phone is not submitting
all the data twice.
Also due to another bug fixed in that patch, the app was actually
doing 3 POST requests. So the patch brings it from from 6 requests
total to 3, for Basic auth.
Yes we're doing this. We need HTTPS anyway since all transmissions
need to be secure. That's why we decided to use basic auth as it was
easier to implement on the server side.
I am not sure if the code I have submitted would interfere with Digest
auth but I don't believe it would. Is that not what the AuthScope
mechanism is for?
Anyway you're free to use this patch or not. I am just happy that
things are working for my deployment. Thanks for your help.
My understanding of the typical server-side implementation of form-based
authentication is that after the authentication, the server would use a
cookie to maintain the identity of the user, and only when the cookie is
missing would you re-auth; I had thought basic authentication would work the
same way; if not, we'd clearly want the preemptive patch in for basic
authentication support.
ODK Collect is reusing the request context across calls so it will honor and
return cookies that the server establishes (can't do digest auth without
that).
Yes.
will
HEAD
request).
all the data twice.
mechanism is for?
Yeah. My understanding of basic auth is that it does not use cookies.
It sends the base 64 encoded credentials with every request in the
headers. Without preemptive support, the httpclient is not even
consulting the httpcontext until it gets a 401, and this is so for
every request. That's why every request is doubled.
So perhaps you could test what I've done with a server running digest
auth (I don't have one). All I know is it's working beautifully on our
system, which is HTTPS, basic auth.
On 28 July 2011 14:16, Mitch Sundt wrote:
> Ah, OK.
> that).
> Mitch
>> Yes.
>> > will
>> > HEAD
>> > request).
>> all the data twice.
>> doing *3* POST requests. So the patch brings it from from 6 requests
>> mechanism is for?
> Mitch Sundt
> Software Engineer
> http://www.OpenDataKit.org
> University of Washington
> mitchellsundt@gmail.com
The patch should probably be changed to do preemptive auth only if the
target host port is 8443 or 443; what we really want to do is only send
credentials if the intended scheme is https, but I don't know how to do
that.
Anyway, that's Carl's business...
the
and
that).
will
preemptive
a
HEAD
request).
all the data twice.
mechanism is for?
I think that's what the AuthScope is for. But sure let's leave it to Carl
In the meantime, the Sending screen and extraneous POST bugs should be
fixed before 1.1.7 is released IMHO as they are both bugs, where as
preemptive auth is an ehancement. I have attached the patches as
separate files to the appropriate issues in the issue tracker.
> that.
> Mitch
>> > Ah, OK.
>> > the
>> > and
>> > that).
>> > Mitch
>> >> Yes.
>> >> > will
>> >> > preemptive
>> >> > a
>> >> > HEAD
>> >> > request).
>> >> all the data twice.
>> >> > server
>> >> mechanism is for?
>> > Mitch Sundt
>> > Software Engineer
> Mitch Sundt
> Software Engineer
