It seems the server URL, username, and password fields should not be
autocapitalized or have suggestions from IME. Attached is a very
simple patch that adds inputType of textNoSuggestions to the
appropriate xml file, in case anyone else has experienced this. I'd
suggest this be added to the next release. I wasn't sure about the
other fields in the prefs screen as I don't use them.
prefs-no-suggestions.diff (843 Bytes)
Thanks Tom. I've filed it at
http://code.google.com/p/opendatakit/issues/detail?id=568.
