Hi guys i want to generate a field value for a form to use it as a primary
key later.
the value of the field may be a "device id"+"a sequential value"+"some
other value"
key later.
other value"
i wonder if the is a way i could get the value of the device id of the
android device i collect information with, or maybe even the login id
You may use uuid() + today() + now() to get the sequence in order (if
that's the purpose of your "sequential value")
uuid() returns a UUID, today() returns the system date, and now() the
system time.
Check this page for bindings reference:
http://opendatakit.org/help/form-design/binding/
Nik
key later.the value of the field may be a "device id"+"a sequential value"+"some
other value"--
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
email to opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>.
Nik, can you confirm that functionality for now()? I have not had it work
like that for me and would be happy if it did.
In my experience using xlsform it just provides today's date. If you
change the type to datetime in the xml it provides a date and time stamp of
the first time it is called, but not an accurate instantaneous timestamp
(calling it 3 times over the course of a survey will supply the same exact
date and time 3 times...).
Let me know if you've had different results.
Jason
I remember that the uuid() is only generated once per instance, so calling
it several times will produce the same result every time.
I confirm that the now() function behaves the same way, and is unexpted.
like that for me and would be happy if it did.In my experience using xlsform it just provides today's date. If you
date and time 3 times...).Let me know if you've had different results.
Jason
that's the purpose of your "sequential value")uuid() returns a UUID, today() returns the system date, and now() the
system time.Check this page for bindings reference: http://opendatakit.**
org/help/form-design/binding/http://opendatakit.org/help/form-design/binding/Nik
primary key later.the value of the field may be a "device id"+"a sequential value"+"some
other value"--
Unsubscribe: opendatakit+unsubscribe@**googlegroups.com
Groups "ODK Community" group.
an email to opendatakit+unsubscribe@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
Nik,
Clayton (of Dimagi) has a patch that fixes the uuid() and random()
bug. The patch should land in the core soon.
The now() bug has been on my todo list for a while. I will take a look
when I get some time.
it several times will produce the same result every time.I confirm that the now() function behaves the same way, and is unexpted.
Jason
other value"--
Thank you Yaw
Nik,
bug. The patch should land in the core soon.The now() bug has been on my todo list for a while. I will take a look
when I get some time.Yaw
design, implementation support, and user training for ODK.On Wed, May 8, 2013 at 5:43 PM, ゴー・ニコライ nikolai.go@gmail.com wrote:
calling
worklike that for me and would be happy if it did.
stamp ofthe first time it is called, but not an accurate instantaneous timestamp
exactdate and time 3 times...).
Jason
other value"--
Groups"ODK Community" group.
anemail to opendatakit+unsubscribe@googlegroups.com.
Thanks for checking it Nik, and thanks for the update Yaw.
Jason
