Hello
I found this discussionhttps://groups.google.com/d/topic/opendatakit/_DdoO_ENhSI/discussion which is from over a year ago and was wondering if anything had changed
with the ability to autofill fields.
We are really looking for two different options:
1 - Fill in a "Select One" spinner with options that are retrieved from an
online database.
2- Autofill a text field, based on a selection from a previous spinner.
I looked at this roadmap http://code.google.com/p/opendatakit/wiki/Roadmap,
but despite the "last updated" date, the info there seems a bit stale.
Anyone know anything about this?
Select One from a database cannot be implemented until a blocking
Javarosa bug is fixed. The bug is outlined at
http://code.google.com/p/opendatakit/issues/detail?id=289. The fix is
non-trivial, so might be good to ask about the best approach on
javarosa-developers@googlegroups.com.
As far as autofilling text fields, the best you can do now is add a
value to a prompt label. You can also use a calculate to fill a node.
Age is
If neither of these are adequate, please file a feature request
detailing the functionality you are looking for.
On Tue, Jan 24, 2012 at 09:35, Feltpad Incorporated wrote:
> Hello
> I found this discussion which is from over a year ago and was wondering if
> anything had changed with the ability to autofill fields.
> online database.
> I looked at this roadmap, but despite the "last updated" date, the info
