it's working fine but in this xml not working properly.
22.xml (80.2 KB)
please see it.
Look at these two lines:
<bind nodeset="/data/Worker_detail/worker_CNIC_details" type="select1" required="true()"/>
<bind nodeset="/data/Worker_detail/worker_cnic" type="string" required="true()" relevant="(/data/worker_CNIC_details != 'Alien')" constraint="(regex(.,'^[0-9]{5}-[0-9]{7}-[0-9]{1}$'))"/>
if the path of worker_CNIC_details is /data/Worker_detail/worker_CNIC_details your expression below should be:
(/data/Worker_detail/worker_CNIC_details != 'Alien') not (/data/worker_CNIC_details != 'Alien')
as I said above, try to use xls instead otherwise it will be super difficult when you will need to create complex forms.
Thanks Grzesiek2010,
I really appreciate your guidance.Now,it's working fine.
I want to know and guide me that::
If Alien is selected then it's possible that automatically entered/filled word "Alien" in "worker_cnic" filed.
Regards,
No it's not possible because we don't support dynamic default answers please read Assigning a dynamic default value to a text-type question
You can do something like described int this asnwer Assigning a dynamic default value to a text-type question - #2 by yanokwa
Thanks Xiphware.
I am very grateful to you.
YW. If you’ve found a satisfactory resolution please mark the thread as solved, thanks.
