Hi. I know that the issue of duplicate values inside a repeat has been already discussed and properly solved. But now I am facing a kind of unpractical behavior when using the constraint not(selected(join(' ',/r/path/to/repeatgroup[position[./group/repeatfield and position(.) != position(current()/../..)]/group/repeatfield),.)) inside nested repeats. In theory, the form works fine but as long as I select or insert the same values exactly in the same order within subsequent repeats. Let's say I have two nested repeat groups: RG1 and RG2. In the first loop of RG1 I select the RG2 classes 'a', 'b', 'c'. In the second loop, I can still select the classes 'a', 'b', 'c' but only in the same order as the first loop, otherwise the form says the answer is not allowed (e.g. if I select 'b', 'c', 'a'). I understand that it is logical from the constraint's point of view, but for my survey, I have to insert the classes the way they appear which is not necessarily the same order as the time before. Any ideas? Thank you very much.
I am using XLSForm to design the form and Central on DigitalOcean to test it
I have searched for solutions but I haven't found yet any topic specifically to this problem related to nested repeat groups.
I would try the attached xls form by selecting the choices 'a', 'b', 'c' in the first loop and the same choices but in a different order ('b', 'c', 'a') the second loop.
5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below.nested-repeat-selects.xlsx (6.7 KB)
