1000 questions is probably not a good idea. We are working on ODK Survey
(an alternative to ODK Collect) that will support "sub-forms" from a larger
form so you can still think of it all as one starting point. But that is
just in alpha right now and won't be ready for production for a while.
A is the better option below.
On Mon, Feb 18, 2013 at 6:06 AM, Samantha Elghanayan < samantha.elghanayan@gmail.com> wrote:
In a related example, if you have a group of questions that is relevant
only if a previous question is answered in a specific way (say a yes/no
that must be answered yes), is one of the following options better than the
other (again to increase speed and/or to avoid crashing):
A. Have a group, where the entire group is relevant on previous answer =
yes
B. No group and just the list of questions, where each question
is relevant on previous answer = yes
Thank you
On Mon, Feb 18, 2013 at 1:36 PM, Samantha Elghanayan < samantha.elghanayan@gmail.com> wrote:
Thanks Gaetano. Unfortunately the main constraint is that it all needs to
be on one form-- and we already have the PDAs.
Instead of having the large section be a repeat group, would it be better
(in terms of speed of loading to PDA, speed of swiping btw questions, and
crashing) to just assume an upward bound of farms (say 10) and copy paste
the repeated section (which is about 1,000 lines) that number of times (in
this example 10)?
On Monday, February 18, 2013, Gaetano Borriello wrote:
Repeats with 100s of questions is generally not a good idea. You may want
to think about how to break things up into separate forms for each farm and
use a simple identifier to tie them together.
On Sat, Feb 16, 2013 at 2:57 PM, Samantha Elghanayan < samantha.elghanayan@gmail.com> wrote:
Hi Chris,
That sounds right from what I understand. Unfortunately, we already have
the phones and they are not very powerful at all. In fact, sometimes just
swiping between questions seems to take forever. Sadly, it's just not an
option to get new phones where we are.
Sam
On Saturday, February 16, 2013, Christopher Robert wrote:
Hi Sam,
It's my understanding that the longer and more complex the form, the more
memory and processing-power you will want on your data-collection devices.
If you haven't already settled on your hardware, you may try some more
powerful devices.
Chris
On Sat, Feb 16, 2013 at 3:38 PM, Sam samantha.elghanayan@gmail.comwrote:
I have a very long survey that works on ODK collect, but it takes quite a
long time to load and sometime crashes. Unfortunately I don't have the
option of separating this into multiple forms (which I've been told would
be ideal).
What are some of the best ways to avoid crashes and increase how quickly
forms load to ODK collect ?
For example, I've been told repeat groups can slow things down. Is this
true? We currently have 1 very small repeat group (4 questions) and 1 very
large repeat group (hundreds of questions that are asked of each farm a
person works on). But no nested repeat groups.
Does having many groups and nested groups slow things down?
Sam
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
email to opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>.
