I'm not sure exactly what you are asking for. If you can provide a 1-2
question form that shows what you are trying to do, that'd help.
If I had to guess, I'd guess that you could solve your problem by
using choice_filter and relevancy. Search the forums for examples
using choice_filter.
On Tue, Oct 11, 2016 at 2:49 PM, Test Isolate wrote:
> Hello Members,
> My name is Bryan from Ghana . I'm a Middle-level developer.
> I'll want some HELP in resolving an issue I have with my XLS Form.
> 1. Users of the App are expected to select a choice (A. Locked Structures
> B. Refusal Cases)
> 2. Based on their selection, the flow of the app is expected to switch to a
> set of questions which
> has cascades.
> 3. I have two different datasets in relation to the Cascades. One dataset
> belongs to (A. Locked Structures) and (B.Refusal Cases)
> But I have issues; How do I present this two datasets for each of the
> choices (A. or B) after users selecting one.
> I can elaborate more. This is my 7th app in ODK but this concept is a little
> bit tricky.
> Thank you in advance.
> Cheers!
> "ODK Community" group.
On Saturday, October 15, 2016 at 11:11:44 AM UTC, Yaw Anokwa wrote:
> Hi Brian,
> Yaw
> On Tue, Oct 11, 2016 at 2:49 PM, Test Isolate <testi...@gmail.com > wrote:
> > Hello Members,
> Structures
> > B. Refusal Cases)
> to a
> > has cascades.
> dataset
> little
> > bit tricky.
> > Cheers!
> Groups
> an
Combine the data sets, add a column for Locked Structures vs Refusal
Cases, and use choice_filter (http://xlsform.org/#cascade) to filter
between the two.
On Sat, Oct 15, 2016 at 8:56 PM, Test Isolate wrote:
> Hello Yaw,
> Thank you for reaching out. I appreciate!
> Kindly find attached a schema (with screenshots) for my ODK app and a copy
> of my XLS form,
> hopefully you will understand what I'm trying to achieve.
> Thank you,
> Bryan Appiah Fei
> PMI/USAID/AIRS
> Ghana
>> Hi Brian,
>> Yaw
>> > Hello Members,
>> > Structures
>> > B. Refusal Cases)
>> > to a
>> > has cascades.
>> > dataset
>> > little
>> > bit tricky.
>> > Cheers!
>> > Groups
>> > an
>> > email to opendatakit...@googlegroups.com.
Thank you, Yaw!
I'll try it out...
You and your team (Nafundi) are doing a GREAT job with
the ODK technology.
I wish you all the best.
On Monday, October 24, 2016 at 5:08:32 PM UTC, Yaw Anokwa wrote:
> Bryan,
> between the two.
> Yaw
> On Sat, Oct 15, 2016 at 8:56 PM, Test Isolate <testi...@gmail.com > wrote:
> > Hello Yaw,
> copy
> > of my XLS form,
> > Thank you,
> > Bryan Appiah Fei
> > PMI/USAID/AIRS
> > Ghana
> >> Hi Brian,
> >> Yaw
> >> > Hello Members,
> >> > Structures
> >> > B. Refusal Cases)
> switch
> >> > to a
> >> > has cascades.
> >> > dataset
> >> > little
> >> > bit tricky.
> >> > Cheers!
> >> > Groups
> send
> >> > an
> Groups
> an
