I'm trying to pull forms from Aggregate with Briefcase, but I get the error "Connection refused". Oddly, Briefcase version 1.10.0 works fine (I was able to pull a form with 6 instances), and the connection error happens with versions 1.11 through 1.14. Could this be a bug? Or is it a proxy related issue?
I tried Briefcase versions 1.10 through 1.14.
Aggregate is installed in Google App Engine, and I can login in the browser and view my forms.
OS is Windows, java version is 8.201 from Oracle.
I'm behind a proxy, but that doesn't seem to be the problem (I think).
- I tried different versions of Briefcase and only 1.10.0 worked. All posterior versions don't connect.
- The same error occurs if I type a random URL endind with appspot.com (e.g. https://asdasdadasd.appspot.com), or if I type the wrong credentials.
- This is the log:
2019-02-19 11:40:57,408 [main] ERROR org.opendatakit.briefcase.Launcher - Error
org.opendatakit.briefcase.reused.http.HttpException: Connection refused
at org.opendatakit.briefcase.reused.http.CommonsHttp.uncheckedExecute(CommonsHttp.java:75)
at org.opendatakit.briefcase.reused.http.CommonsHttp.execute(CommonsHttp.java:53)
at org.opendatakit.briefcase.reused.RemoteServer.testPull(RemoteServer.java:133)
at org.opendatakit.briefcase.operations.PullFormFromAggregate.pullFormFromAggregate(PullFormFromAggregate.java:85)
at org.opendatakit.briefcase.operations.PullFormFromAggregate.lambda$static$0(PullFormFromAggregate.java:55)
at org.opendatakit.common.cli.Cli.lambda$run$4(Cli.java:130)
at java.lang.Iterable.forEach(Unknown Source)
at org.opendatakit.common.cli.Cli.run(Cli.java:127)
at org.opendatakit.briefcase.Launcher.main(Launcher.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
- If I type a random domain name, a different error appears (e.g. appspottttt.com --> java.net.UnknownHostException). This makes me think that the problem is not the proxy, but I may be wrong.
- I used wireshark to analyse the packets, here's what I get:
