I am trying to pull the data from the ODK folder which I copied from the tablet. I used ODK briefcase v1.8.0 and chose Custom path to ODK Directory. Unfortunately, I am not able to see any forms to pull. I have also installed Java 8 in the system.
Any help will be greatly appreciated.
Ensure that all filled-in forms on ODK Collect are finalized. If they are not finalized, you should either delete them via ODK Collect's 'Delete Saved Form' button or make a back-up copy of the '/sdcard/odk' directory on your device, delete the incomplete forms in ODK Collect. Source: here.
If this doesn't manage it, explain me in details what you've donne. I'm a starter like.
Thank
I already did all the steps based on the instructions from here: http://docs.opendatakit.org/briefcase-forms/ and still, I am not able to pull out the data. Is there anything I am missing in here?
Here are the screenshots for the folder structure and the settings for the Briefcase. Kindly take a look at it and let me know if there's anything missing.
This is very odd. @Amayuga, I don't know how sensitive your data is, but if it's not sensitive, can you please zip up the odk folder and send it to me? I will send you a PM with a link.
