and it says at the bottom of that conversation that in windows 8 you have
to install both the 32bit AND the 64bit versions - so I have done that and
now when I change the directory at the command prompt and type 'java
-jar"ODK ..." etc I get this message instead: "Unrecognized option:
-jarODK... Error: could not create the java virtual machine, Error: a fatal
exception has occurred. Program will exit"
Does any of this mean anything to any of you?
On Wednesday, December 19, 2012 9:51:10 AM UTC-8, Zachary Burt wrote:
> I'm not sure what changed - a couple of days ago I pulled my forms from
> Aggregate using Briefcase just fine.
> But this morning I tried to export those forms and it just froze while
> removing the encryption from the first instance. And just now when I tried
> to pull forms again, when I tried to log-in through the 'connect' window it
> just froze up without connecting.
> I have no idea what's going on with briefcase. Any help is much
> appreciated!
> Zach
If you go to the command line and you type "java -version", what do you get?
On Wed, Dec 19, 2012 at 5:23 PM, Zachary Burt wrote:
> OK, so I found this random posting of advice:
> http://superuser.com/questions/356034/how-to-install-java-enviroment-on-windows-8
> and it says at the bottom of that conversation that in windows 8 you have to
> install both the 32bit AND the 64bit versions - so I have done that and now
> when I change the directory at the command prompt and type 'java -jar"ODK
> ..." etc I get this message instead: "Unrecognized option: -jarODK... Error:
> could not create the java virtual machine, Error: a fatal exception has
>> appreciated!
>> Zach
" 'java -version' is not recognized as an internal or external command,
operable program or batch file "
> get?
> have to
> now
> -jar"ODK
> Error:
> tried
> window it
> >> appreciated!
> >> Zach
NO, sorry!! I tried it again, now that I have both versions of java on
there, now I get "java version "1.7.0_10" Java(TM) SE Runtime Environment
<build 1.7.0_10-b18> Java HotSpot 64-Bit Server VM <build 23.6-b04,
mixed mode)
>> get?
>> have to
>> now
>> -jar"ODK
>> Error:
>> from
>> tried
>> window it
>> >> appreciated!
>> >> Zach
Could this have to do with the migration to hrd from master slave? maybe I
did it incorrectly? I am able to log in to aggregate and view the
(encrypted) data, but maybe there is something that I did not do correctly
which is interfering with briefcase?
> Java HotSpot 64-Bit Server VM mixed mode)
>>> get?
>>> have to
>>> and now
>>> -jar"ODK
>>> Error:
>>> has
>>> from
>>> while
>>> tried
>>> window it
>>> >> appreciated!
>>> >> Zach
