Hey ODK folks, I have noticed that the string field with numbers in
control:appearance column has some issues.
Basically, it doesn't except a number with more than 10 digits (which, for
us, is the point of using this as opposed to the integer field).
See http://formhub.org/prabhasp/forms/phone_number_test for a form with an
error.. it just contains two questions, one question of type string with
numbers as appearance and bind:required not set to true, and the other the
same with required set to true.
In the first question, if you enter an 11 digit number, swipe through, and
swipe back, the 11-digit number is gone.
In the second question, if you enter an 11 digit number, you will get a
"Sorry, this response is required!" message.
(Using the latest ODK from
http://code.google.com/p/opendatakit/downloads/detail?name=ODK%20Collect%20v1.1.7.apk&can=2&q=
on an HTC Sensation 4G, Android version 2.3.4)
Hi Prabhas,
I filed this bug at
http://code.google.com/p/opendatakit/issues/detail?id=550 a few weeks
ago. Carl is working on it right now and he'll update that ticket when
the fix is done.
Hi Yaw,
It turns out that we also need this fix for our surveys.
The fix appears to be in, but do you think there's a new RC build coming on
the horizon? If not, I will build an intermediate release just for our own
deployment, but I'd like to avoid that if a new RC is around the corner.
Chris
On Monday, April 16, 2012, Yaw Anokwa wrote:
Hi Prabhas,
I filed this bug at
the fix is done.
On Mon, Apr 16, 2012 at 10:04, Prabhas Pokharel <prabhas.pokharel@gmail.com <javascript:;>> wrote:
for
an
the
and
Post: opendatakit@googlegroups.com <javascript:;>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:;>
Chris,
If you are using Collect 1.1.7 from Market, it should have auto
updated with the fix a few hours ago. If you downloaded Collect 1.1.7
from the web, just re-download it from
http://code.google.com/p/opendatakit/downloads/list.
On Mon, Apr 16, 2012 at 22:09, Christopher Robert wrote:
> Hi Yaw,
> Thanks,
> Chris
>> Hi Prabhas,
>> I filed this bug at
>> the fix is done.
>> Yaw
>> > for
>> > an
>> > the
>> > and
Hi Yaw,
Thanks for the quick reply! I didn't realize that you slipstreamed fixes
like this into the old v1.1.7.
Unfortunately, we're using v1.2 RC1 for the encryption support, so we'd
need an updated version of that one.
Chris
On Tuesday, April 17, 2012, Yaw Anokwa wrote:
Chris,
On Mon, Apr 16, 2012 at 22:09, Christopher Robert <chris_robert@hksphd.harvard.edu <javascript:;>> wrote:
Hi Yaw,
on
own
Chris
Hi Prabhas,
I filed this bug at
the fix is done.
for
with
an
with
the
and
a
We try to push 1.1.7 issues as quickly as possible since that's the
released version.
No ETA on v1.2 builds. I'm sure Mitch will patch it in as soon as he can.
On Mon, Apr 16, 2012 at 22:26, Christopher Robert wrote:
> Hi Yaw,
> Unfortunately, we're using v1.2 RC1 for the encryption support, so we'd need
> Thanks,
> Chris
>> Chris,
>> Yaw
>> > Hi Yaw,
>> > on
>> > own
>> > Thanks,
>> > Chris
>> >> Hi Prabhas,
>> >> I filed this bug at
>> >> the fix is done.
>> >> Yaw
>> >> > (which,
>> >> > for
>> >> > with
>> >> > an
>> >> > with
>> >> > other
>> >> > the
>> >> > through,
>> >> > and
>> >> > a
The fix has also been checked into the main (1.2) branch. So we'll just
need to update the RC (or push a new one).
released version.
On Mon, Apr 16, 2012 at 22:26, Christopher Robert chris_robert@hksphd.harvard.edu wrote:
Hi Yaw,
need
Chris
Chris,
On Mon, Apr 16, 2012 at 22:09, Christopher Robert chris_robert@hksphd.harvard.edu wrote:
Hi Yaw,
coming
on
own
corner.
Chris
Hi Prabhas,
I filed this bug at
weeks
when
the fix is done.
On Mon, Apr 16, 2012 at 10:04, Prabhas Pokharel prabhas.pokharel@gmail.com wrote:
(which,
for
with
an
with
other
the
through,
and
get
a
