Hello everyone,
when I want to run aggregate in IntelliJ Idea, there is already an error with building it:
Build file '/home/elly/Dokumente/Hiwi DLR/aggregate/build.gradle' line: 20
Plugin [id: 'de.fuerstenau.buildconfig', version: '1.1.8'] was not found in any of the following sources:
When I want to run it with the Gradle Task AppStartWar, there is this error:
Could not set process working directory to '/home/elly/.gradle/daemon/6.1.1/odk-aggregate': could not setcwd() (errno 2: Datei oder Verzeichnis nicht gefunden)
My Gradle Version is 5.0, I'm not sure if it is the problem.
Does anyone know what the problem could be?
Thank you,
Elena
