I am using ODKcollect and I have several questions in my form (9 in total) giving yes or no answers that are coded "1" and "0" on the choices tab. Is it possible to have a calculate function following these questions that calculates the sum of the coded values? So theoretically it would calculate a sum from 0 to 9?
a sum from 0 to 9?
If I end up having all of the questions as integers with the constraint of
1 or 0 could I use a calculation argument like this:
if(${vitaminrich}= '1' or ${darkgreenleaf}= '1' or ${othervegetables}= '1'
then .= '1') else .= '0'
My goal is to have it calculate as a 1 if any one of those elements are
identified as a 1 and if not it would be a 0. However I couldn't find any
documentation on IF/ELSE functions in ODK.
Thanks in advance for your help,
-Brett
On Monday, November 16, 2015 at 11:38:29 PM UTC+3, Mitch Sundt wrote:
> If you are using select1, note that the value is a string value ("1") and
> not a number (1).
> To convert to a number, you can use the int() function.
> See https://opendatakit.org/help/form-design/binding/ for the various
> functions that are available.
> You could then write a computation like:
> int(${yn_q1}) + int(${yn_q2}) + int(${yn_q3})
> On Mon, Nov 16, 2015 at 3:37 AM, <brettco...@gmail.com > wrote:
>> Hi there,
>> Thanks very much for your help,
>> -Brett
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Since Y and N are coded 1 and 0 in the choices sheet, use question1 +
question 2 up to 9. See attached file.
Best and Regards
Ronald Munjoma
Hi?
Is there a 'relevant' that restricts certain choice options (being
selected) based on a previous response (ie being Male excludes an option of
getting pregnant) without skipping questions?
I hope this makes sense.
I need help on this. Thanks in advance.
Louis...
On Tue, Nov 17, 2015 at 9:56 PM, Mitch Sundt wrote:
If-then-else is called 'conditional' -- see the bindings link in the
previous e-mail.
Best and Regards
Ronald Munjoma
Thanks a lot, Ronald. Excellent and simplified example.
On Tuesday, November 17, 2015 at 8:29:02 AM UTC-5, Ronald Munjoma wrote:
> Hi Bret,
> On 16 November 2015 at 13:37, <brettco...@gmail.com > wrote:
>> Hi there,
> Best and Regards
> Ronald Munjoma
>> -Brett
> Best and Regards
> Ronald Munjoma
> +263 775 625 283
> [image: --]
> Ronald Munjoma
> [image: https://]about.me/ronaldmunjoma
Need ODK consultants? Nafundi provides form design, server setup, in-field
training, and software development for ODK. Go to https://nafundi.com to
get started.
Hi?
Best and Regards
Ronald Munjoma
get started.
Hi?
Best and Regards
Ronald Munjoma
See attached for correction, its best to not have the filter choice column
name on choices name as the same name as the 'name' on the survey tab. I
renamed filter_choice headings in choices tab to make it a bit more clear.
On Wednesday, November 18, 2015 at 5:53:45 AM UTC-5, Louis Omoya wrote:
> I need help to make filtering work. I want it to filter Auditors and
> Districts by region, then Sub-county/Parish by Districts.
> I am following an example, and cant figure out what I am doing wrong.
> Thank you in advance.
> Louis...
> On Wed, Nov 18, 2015 at 9:40 AM, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Louis,
>> You might be able to use a choice_filter to restrict the choices. See
>> https://groups.google.com/d/msg/opendatakit/LAp3vvsUtag/fG0xaxYkAAAJ for
>> an example.
>> Yaw
>> in-field training, and software development for ODK. Go to
>> https://nafundi.com to get started.
>> On Wed, Nov 18, 2015 at 1:13 PM, Louis Omoya <louis...@gmail.com > wrote:
>>> Hi?
>>> Louis...
>>> On Tue, Nov 17, 2015 at 9:56 PM, Mitch Sundt <mitche...@gmail.com > wrote:
>>>> previous e-mail.
>>>> On Tue, Nov 17, 2015 at 5:28 AM, ronald munjoma <sim...@gmail.com > wrote:
>>>>> Hi Bret,
>>>>>> Hi there,
>>>>> Best and Regards
>>>>> Ronald Munjoma
>>>>>> -Brett
>>>>>> Groups "ODK Community" group.
>>>>>> send an email to opendatakit...@googlegroups.com .
>>>>> Best and Regards
>>>>> Ronald Munjoma
>>>>> +263 775 625 283
>>>>> [image: --]
>>>>> Ronald Munjoma
>>>> Mitch Sundt
>>>> Software Engineer
>>>> mitche...@gmail.com
Thanks alot. I will try this ASAP. Thank you for the relief.
Louis...
On Wed, Nov 18, 2015 at 5:39 PM, Lloyd Owen Banwart <lloyd.banwart@gmail.com wrote:
Hi Louis,
~Lloyd
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
Hi?
Best and Regards
Ronald Munjoma
send an email to opendatakit...@googlegroups.com.
Best and Regards
Ronald Munjoma
+263 775 625 283
