I want to populate two nodes with the answer from a select 1 question in a cascading select.
I'm trying to use the calculate function in the bind for the second node.
<h:head>
<h:title>Cascading Regional</h:title>
<instance>
<cr id="cascading_regional_0.3" version="2015081701">
<activity/>
</cr>
</instance>
<instance id="activity">
<root>
<item>
<value>Repair Pothole (201)</value>
<name>repair_pothole_201</name>
<unitl>Each</unitl>
<unitv>each</unitv>
</item>
<item>
</root>
</instance>
<bind nodeset="/cr/activity" type="select1"/>
<bind nodeset="/cr/quantity_and_units/unit" calculate="instance('activity')/root/item/unitv [name= /cr/activity ]" type="string"/>
</model>
</h:head>
<h:body>
<select1 ref="/cr/activity">
<label>Activity</label>
<itemset nodeset="instance('activity')/root/item">
<value ref="name"/>
<label ref="value"/>
</itemset>
</select1>
</h:body>
</h:html>
Is this possible or should I be using a different method?
(I deleted your other post -- both questions have the same answer)
This is a quirk of XPath. In this bind:
[name= /cr/activity]" type="string"/>
The selection condition (in bold above) is evaluated in the context of the
instance('activity').
So it is looking for 'name' under the instance('activity'
)/root/item/unitv node.
But it is also looking for '/cr/activity' under the instance('activity')
root-level node.
When writing these formulas, you need to explicitly specify whether the
field is in the main (un-named) instance, or one of these read-only named
instances. The correct expression is:
[*name= instance()/cr/activity* ]" type="string"/>
This also applies to expressions like position(..) -- you need to write
this as position(instance()..)
Not sure if that parses correctly. If not, you can always store
position(..) in a field, then reference that field.
Note that *instance()foo *will reference the 'foo' field in the current
repeat group.
cascading select.
<h:head>
<instance>
2015081701">
<root>
<item>
<unitl>Each</unitl>
<unitv>each</unitv>
</item>
<item>
</root>
</instance>
type="string"/>
</h:head>
<h:body>
<value ref="name"/>
</itemset>
</select1>
</h:body>
</h:html>
The selection condition (in bold above) is evaluated in the context of the instance('activity').
So it is looking for 'name' under the instance('activity')/root/item/unitv node.
But it is also looking for '/cr/activity' under the instance('activity') root-level node.
When writing these formulas, you need to explicitly specify whether the field is in the main (un-named) instance, or one of these read-only named instances. The correct expression is:
This also applies to expressions like position(..) -- you need to write this as position(instance()..)
Not sure if that parses correctly. If not, you can always store position(..) in a field, then reference that field.
Note that instance()foo will reference the 'foo' field in the current repeat group.
<h:head>
<model>
<instance>
<activity/>
</cr>
</instance>
<root>
<item>
<unitl>Each</unitl>
<unitv>each</unitv>
</item>
<item>
</root>
</instance>
</model>
</h:head>
<h:body>
<value ref="name"/>
</itemset>
</select1>
</h:body>
</h:html>
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
mitche...@gmail.com
Thanks heaps Mitch, it even makes sense to this noob.
Richard
<h:head>
<model>
<instance>
<activity/>
</cr>
</instance>
<root>
<item>
<unitl>Each</unitl>
<unitv>each</unitv>
</item>
<item>
</root>
</instance>
</model>
</h:head>
<h:body>
<value ref="name"/>
</itemset>
</select1>
</h:body>
</h:html>
mitche...@gmail.com
[name= instance()/cr/activity ]
gave the below error in ODK validate?
org.javarosa.xpath.XPathUnsupportedException: XPath evaluation: unsupported construct [instance() function used with 0 arguements. Expecting 1 arguement]
Argh! So much for writing responses from memory!
The two forms are:
current()
and
instance('instancename')
So wherever I said instance(), replace that with current()
Sorry.
root-level node.
repeat group.
a cascading select.
<h:head>
<model>
<instance>
2015081701">
<activity/>
</cr>
</instance>
<root>
<item>
(201)
<unitl>Each</unitl>
<unitv>each</unitv>
</item>
<item>
</root>
</instance>
type="string"/>
</model>
</h:head>
<h:body>
<itemset
<value ref="name"/>
</itemset>
</select1>
</h:body>
</h:html>
mitche...@gmail.com
