Hi list,
I am using groups as a selection structure to select one of two variables
to be shown to enter a variable depending on a previous value selected.
I have set both integer variables to 0 for default so that my calculation
will not be blank as only one variable will be shown to enter a value at a
time.
However I still have to enter both variables regardless in order to make
it work. If I don't it will show a blank for the calculated field.
Any advice/tips appreciated
Sounds like a bug in your form. Build a smallest form that does what
you are trying to accomplish and if you are still having the problem,
send the test form to the list.
On Sun, Aug 2, 2015 at 5:55 AM, Nomeneta Saili nome.saili@gmail.com wrote:
Hi list,
I am using groups as a selection structure to select one of two variables to
time.
However I still have to enter both variables regardless in order to make it
