Dear Kobo Team,
I have two scenario where i need to have totals Yes and Total Response and also the Outcome which depend on questions answered and also skip where the questons where its not applied
Below is the table;
Question response1 response2 Totalyes totalresponses
q1 yes no 1 2
q2 yes yes 2 2
q3 yes no 1 2
q4 yes yes 2 2
Outcome 1 0 1 2
If all the questions are Yes then Outcome is 1 and if any of the question is No the outcome is 0
and also calculating total responses per question
Which is the best approach and function to use in the scenario above
sampled.xls (28.5 KB)
