I am finding it difficult to calculate or sum up a group of selected yes or no function in the form.
2. What you have you tried to fix the problem?
select_one yes_no a_1_1_1 Availability of grass on the compound list
select_one yes_no a_1_1_2 Grass should be green list
select_one yes_no a_1_1_3 Not mixed with weeds (other grasses) list
select_one yes_no a_1_1_4 Area well ‘boxed’ by kerbs list
select_one yes_no a_1_1_5 Grass cut (mowed) very low list
select_one yes_no a_1_1_6 No bare area list
calculate scores_Display [within the Calculation Column] scores_Display = ${a_1_1_1} +${a_1_1_2}+${a_1_1_3}+${a_1_1_4}+${a_1_1_5}+${a_1_1_6}
Just FYI, this doesn't actually matter - XPath evaluation of expressions will automatically 'typecast' their operands appropriately; ie "${A} + ${B}" will implicitly be evaluated as "number(${A}) + number(${B})"
Not working as described... is not very helpful taking into account that YOU need help please try to explain what's wrong instead. I tested it and it added 1 point for each yes. Did you get something else?
Can you please describe what is not working with @Grzesiek2010 form? If you load his form into XLSForm online and run it (under Enketo) you will see that it is correctly displaying the total for the first section:
