I could´nt see the results that I have been chosen in a repeat question.
I'm using ODK Collect.
I posted recently the problem in a form but I could'nt resolve it.
Run the sample XLS form.
sumexample_edited.xls (31 KB)
Hi Sebastian,
Form you have uploaded has duplicated names (row 10 and 11).
After erasing one, in calculation you can use directly ${member} because you are in the repeat group. In fact you do not need to use an extra calculate, just directly ${member} .Also relevant in row 11 is redundant because is in repeat group that has the same relevance.
Your form:
Version 1:
Final version:
Thank you very much Alexander!
In the same example, my last question is how to show (0) instead (NaN) in the note, when there is no value.
I attached the example.
try changing to:
subtotal = coalesce(${value1},0) + coalesce(${value2},0) + coalesce(${value3},0)
See coalesce() for details. Bascially if the value is null (ie hasn't been answered) it'll return 0. Without 'coalescing', any nulls in an arithmetic expression will cause the whole calculation to become NaN
Great man! you are the best!
