Call on or output value of elements within a repeat
Is there any way to call or output the values from the child nodes within a
repeat (either now or coming in 1.1.7)? I have read through the boards, and
it does not seem like there is any simple way to auto-increment or call an
element within a repeat without developing new classes... for example, if
I have a loop to collect all individuals within a household, is there anyway
to call on the specific individuals within that household from outside the
repeat... or can I at least output all the individuals names with something
like , even in the
repeat? Thanks!
javarosa has some of these capabilities. i'm not sure if they've made it
into the latest version of ODK.
for example, i believe you can do:
to print a comma-separated list of all children, from outside the repeat.
you can also refer to data inside the repeat (as well as the current repeat
index and total # of repetitions) for repetition headers and captions.
generally, though, you cannot refer to a specific repetition within a group
('#2 of 5' or 'the child whose name is carl'). you can only refer to the
repetition you're currently inside, or all repetitions in aggregate (like
with the comma-separated list example above).
like , even in the
repeat? Thanks!
this will all be in the 1.1.7 release (which is still on track for a
mid may beta)
··· On Fri, May 13, 2011 at 07:35, Drew Roos wrote: > javarosa has some of these capabilities. i'm not sure if they've made it > into the latest version of ODK. > > for example, i believe you can do: > > > > to print a comma-separated list of all children, from outside the repeat. > > you can also refer to data inside the repeat (as well as the current repeat > index and total # of repetitions) for repetition headers and captions. > generally, though, you cannot refer to a specific repetition within a group > ('#2 of 5' or 'the child whose name is carl'). you can only refer to the > repetition you're currently inside, or all repetitions in aggregate (like > with the comma-separated list example above). > > > On Fri, May 13, 2011 at 10:04 AM, louis wrote: >> >> Is there any way to call or output the values from the child nodes within >> a repeat (either now or coming in 1.1.7)? I have read through the boards, >> and it does not seem like there is any simple way to auto-increment or call >> an element within a repeat without developing new classes... for example, >> if I have a loop to collect all individuals within a household, is there >> anyway to call on the specific individuals within that household from >> outside the repeat... or can I at least output all the individuals names >> with something like , even >> in the repeat? Thanks! >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >
great, thanks so much! I look forward to seeing 1.1.7... sounds like
that is next week, sometime?!
mid may beta)
made it
repeat.
current repeat
captions.
a group
to the
(like
within
boards,
increment or call
example,
there
from
names
the beta will be out soon. can't promise anything exact...
··· On Fri, May 13, 2011 at 08:13, Louis Fazen wrote: > great, thanks so much! I look forward to seeing 1.1.7... sounds like that is > next week, sometime?! > > On May 13, 2011, at 5:59 PM, Yaw Anokwa wrote: > >> this will all be in the 1.1.7 release (which is still on track for a >> mid may beta) >> >> On Fri, May 13, 2011 at 07:35, Drew Roos wrote: >>> >>> javarosa has some of these capabilities. i'm not sure if they've made it >>> into the latest version of ODK. >>> >>> for example, i believe you can do: >>> >>> >>> >>> to print a comma-separated list of all children, from outside the repeat. >>> >>> you can also refer to data inside the repeat (as well as the current >>> repeat >>> index and total # of repetitions) for repetition headers and captions. >>> generally, though, you cannot refer to a specific repetition within a >>> group >>> ('#2 of 5' or 'the child whose name is carl'). you can only refer to the >>> repetition you're currently inside, or all repetitions in aggregate (like >>> with the comma-separated list example above). >>> >>> >>> On Fri, May 13, 2011 at 10:04 AM, louis wrote: >>>> >>>> Is there any way to call or output the values from the child nodes >>>> within >>>> a repeat (either now or coming in 1.1.7)? I have read through the >>>> boards, >>>> and it does not seem like there is any simple way to auto-increment or >>>> call >>>> an element within a repeat without developing new classes... for >>>> example, >>>> if I have a loop to collect all individuals within a household, is there >>>> anyway to call on the specific individuals within that household from >>>> outside the repeat... or can I at least output all the individuals names >>>> with something like , >>>> even >>>> in the repeat? Thanks! >>>> >>>> -- >>>> Post: opendatakit@googlegroups.com >>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >>> -- >>> Post: opendatakit@googlegroups.com >>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >
