Hey all I am totally new to ODK and I am wondering how does excel gets converted into xlsform that I can view on my browser? Or what are the steps thats been taken programmatic in order for me to see my excel fields in my form?
But the over all problem that I am trying to solve is how can I add my costume metadata into excel for each field with extra validation or parameters? The problem I am having is that I need to pass more "hidden" information about the field into API. Also I am not sure how does ODK API work and can I have access to data from there using python
The most popular conversion tools are XLSForm Online and XLSForm Offline. These are wrappers on pyxform, the library that does the actual conversion from XLSForm to XForms. More at https://docs.opendatakit.org/xlsform/. Viewing the form in a browser is done with Enketo.
Easiest way to do this end-to-end is to go to http://opendatakit.org/xlsform, do the conversion, and view it with Enketo.
As to getting data out of Aggregate, https://docs.opendatakit.org/briefcase-api/ is the API for doing that. If you can provide more detail about what exactly you are trying to do, you'll likely get more targeted help.
Okay and if I were to set up the project locally with pyxform, can I modify code in there?
Like getting the passed in fields for example?
If I were to use calculates option, will it be possible for me to add other values to it that could look something like this:
or to something where I will know what values belong to what name. Because one of the problems is adding more rules for each field (in house rules)
Also, is OpenRosaAPI only written in Java or can I use Python or PHP for it?
Yes, you can modify the code are you see fit, but note that you will be responsible for supporting it and keeping up with the changes on the stock codebase.
Our tools are written in a variety of languages but the APIs are language agnostic.
Also when I do create an excel file, is there a way to a default value from sibling_number as a constraint for another filed? Please find attached image.
Or will this be the right place where I will be using calculates?
