Can ODK be used for Manufacturing
I assume ODK because it's open source can be used in a manufacturing
environment collecting data from machines, test equipment, assembly line
conveyors etc. If so does anyone have any information this being done so I
may talk with person or persons involved.
If it is just data collection about your manufacturing process then there
is strong chance that it would work, but still you will have to see if it
meet all your data demands which includes any data constraints or how you
want to consume collected data.
Lucky,
Most people use ODK to replace a paper form or survey or workflow. ODK
can take that manual process, regardless of the sector, and give you
richer, more accurate, and more timely data collection.
It's open source nature means you can hire a developer to customize it
to do precisely what you want, but if you are just looking to replace
paper forms, ODK will work well out of the box for you.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
On Sun, Dec 15, 2013 at 10:15 PM, Ayub nrspaggregate@gmail.com wrote:
If it is just data collection about your manufacturing process then there is
strong chance that it would work, but still you will have to see if it meet
all your data demands which includes any data constraints or how you want to
