I have tried 20 times to get the token accepted, tried all the instructions.
Fail, fail, fail
I cannot even get to use the whole ODK program because of this.
I have tried on firefox and chrome, loaded latest versions of java and aggregate 1.9.48.
Just emailing that it doesn't work does not enable anyone to help you solve
your difficulties.
(0) What type of computer are you using? Windows / MacOSX / Linux variant?
(1) Are you using the ODK Aggregate 1.4.13 installer? Download it from
here: https://opendatakit.org/downloads/download-category/aggregate/
(2) The Google Cloud Platform project id / application MUST NOT be created
as a Google Apps Domain project.
(3) When running the installer, it is apparently important for the
application id (project id) to be in EXACTLY the same lowercase / uppercase
form as shown on Google Cloud Platform. If your project is "myapp" on GCP,
you CANNOT enter "MyApp" in the installer. It will fail (this is apparently
a recent change at Google).
(4) Before launching the upload tool, open your default browser, go to
gmail.com, and Sign Out (click top right icon and choose "Sign Out"). And
CLOSE ALL WINDOWS for that browser. Then open that browser, go to gmail.com,
sign in with the same gmail account as you used when you created the Google
Cloud Platform account.
Launch the upload tool. I assume you are doing all of the above correctly.
(Q1:) Does it open your default browser to a page where you are asked to
allow access to your gmail account?
(Q2:) After allowing access, can you select-all in the text box and copy to
clipboard? Note that the token is much wider than the visible text. You
need to carefully select the entire text in that box.
(Q3:) Are you able to locate the pop-up window in which to paste the
token? And choose OK?
(Q4:) After you choose OK, there should be some output scrolling in the
upload tool window. The output should end with "status : Action Succeeded!".
Does it? e.g., here is an example output:
getToken : ********************************************************
getToken : There is a new version of the SDK available.
getToken : -----------
getToken : Latest SDK:
getToken : Release: 1.9.50
getToken : Timestamp: Mon Feb 27 15:21:33 PST 2017
getToken : API versions: [1.0]
getToken :
getToken : Your SDK:
getToken : Release: 1.9.48
getToken : Timestamp: Wed Oct 26 13:44:58 PDT 2016
getToken :
getToken : Please visit https://developers.google.com/appengine/downloads
for the latest SDK.
getToken!: Mar 23, 2017 3:21:15 PM
com.google.appengine.repackaged.com.google.api.client.extensions.java6.auth.oauth2.FileCredentialStore
getToken!: WARNING: unable to change file permissions for everybody:
C:\Users\Admin.appcfg_oauth2_tokens_java
getToken : The following URL can be used to authenticate:
getToken :
https://accounts.google.com/o/oauth2/auth?access_type=offline&approval_prompt=force&client_id=550516889912.apps.googleusercontent.com&redirect_uri=urn:ietf:wg:oauth:2.0:oob&response_type=code&scope=https://www.googleapis.com/auth/appengine.admin%20https://www.googleapis.com/auth/cloud-platform
getToken : Attempting to open it in your browser now.
getToken : Please enter code:
getToken : Reading application configuration data...
getToken!: Mar 23, 2017 3:21:34 PM
com.google.apphosting.utils.config.IndexesXmlReader readConfigXml
getToken!: INFO: Successfully processed
./LegacyRemoval\WEB-INF/datastore-indexes.xml
getToken :
getToken :
getToken : Beginning interaction for module default...
getToken : max_blob_size: 32000000
getToken : max_file_count: 10000
getToken : max_file_size: 32000000
getToken : max_files_to_clone: 2000
getToken : max_total_file_size: 9223372036854775807
getToken : Success.
getToken : Cleaning up temporary files for module default...
getToken :
getToken!:
(Q5:) If you then click the "Upload ODK Aggregate" button, what is the
output? It should end with the same "status : Action Succeeded!". If it
doesn't, please select all the output and send it.
On Thu, Mar 23, 2017 at 6:16 AM, wrote:I have tried 20 times to get the token accepted, tried all the
instructions.
Fail, fail, fail
aggregate 1.9.48.--
"ODK Developers" group.
