I had just renamed the packages in the android studio. So that I could customize my app and publish it. After I rename it I am getting the following error
E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.gic.spade.android, PID: 17416
java.lang.RuntimeException: Unable to create application com.gic.spade.android.application.Collect: org.javarosa.core.util.externalizable.CannotCreateObjectException: CollectSetGeopointAction: not found
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6065)
at android.app.ActivityThread.-wrap1(Unknown Source:0)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1764)
at android.os.Handler.dispatchMessage(Handler.java:105)
at android.os.Looper.loop(Looper.java:164)
at android.app.ActivityThread.main(ActivityThread.java:6944)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:327)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1374)
Caused by: org.javarosa.core.util.externalizable.CannotCreateObjectException: CollectSetGeopointAction: not found
at org.javarosa.core.services.PrototypeManager.registerPrototype(PrototypeManager.java:19)
at com.gic.spade.android.logic.FormController.initializeJavaRosa(FormController.java:137)
at com.gic.spade.android.application.Collect.initializeJavaRosa(Collect.java:287)
at com.gic.spade.android.application.Collect.onCreate(Collect.java:199)
at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1125)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6062)
