Cascading select within repeat workaround
Hi, Mitch.
Would just like to let you know that I was able to workaround the problem
with cascading selects within repeat. I followed the instructions on
"External Itemsets" from the ODK Help page and edited the sample
cascading_select_external_itemsets.xml file. I inserted group tags in the
instance section (open and close 'address' tags) and did the same in the
body section, I inserted group and repeat tags. Here's the edited xml file.
Just wanted to share in case others need a workaround on the subject.
Vinia
cascading_select_external_itemsets.xml (1.93 KB)
Hi. Just wondering why this didn't get through. Was this post moderated?
Just wanted to know if this was not posted because the workaround didn't
work for others.
Thanks :slight_smile:
··· ---------- Forwarded message ---------- From: Vinia Marciano Date: Sun, Apr 20, 2014 at 9:24 PM Subject: cascading select within repeat workaround To: opendatakit@googlegroups.com
Hi, Mitch.
Vinia
This was posted on April 20th
Perhaps your spam filter doesn't like attachments?
work for others.
Hi, Mitch.
Vinia
Will check. Thanks, Mitch.
On Tue, May 13, 2014 at 6:34 PM, Vinia Marciano viniamarciano@gmail.comwrote:
work for others.
Hi, Mitch.
Vinia
Hi. Just wondering why this didn't get through. Was this post moderated? Just wanted to know if this was not posted because the workaround didn't work for others.
Hi, Mitch.
Would just like to let you know that I was able to workaround the problem with cascading selects within repeat. I followed the instructions on "External Itemsets" from the ODK Help page and edited the sample cascading_select_external_itemsets.xml file. I inserted group tags in the instance section (open and close 'address' tags) and did the same in the body section, I inserted group and repeat tags. Here's the edited xml file.
Vinia
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
mitche...@gmail.com
Dear Vinia,
Thanks so much for posting your workaround. that is what i have been looking for since yesterday. i have one question to ask you:
in the instruction given in the external itemsets, it is said "In the <bind nodset="..." change the type="select1" to type="string" for any of your new itemsets". However in examples of yours and Mitch's, you both remain the "select1" for the type of for first nodeset of "state". could you tell me the reason?
Regards
Zaixing
··· On Wednesday, May 14, 2014 1:35:16 PM UTC+11, vinia wrote: > On Wed, May 14, 2014 at 10:21 AM, Mitch Sundt wrote: > On Tue, May 13, 2014 at 6:34 PM, Vinia Marciano wrote: > ---------- Forwarded message ---------- > From: Vinia Marciano > Date: Sun, Apr 20, 2014 at 9:24 PM > Subject: cascading select within repeat workaround > To: opend...@googlegroups.com
